Go to Post Competitive games are won by point differentials, not by point potentials. - JesseK [more]
Unread 04-02-2017, 11:23
serdaruluer serdaruluer is offline
FRC #6431 (NoktaParantez)
Rookie Year: 2017
serdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of light
2.5" CIM Motor stops when climbing
Is the CIM motor enough to lift robot? After rope winds our motor stops and robot can not go up.
Unread 04-02-2017, 11:28
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: 2.5" CIM Motor stops when climbing
What gear reduction (if any) do you have connected to the CIM? What drum/winch diameter?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 04-02-2017, 11:33
Rookie Year: 2017
Any.
Unread 04-02-2017, 11:34
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Can you post a picture of your robot? It would help us figure out a solution.
A CIM motor is plenty powerful enough to make the robot climb.
Unread 04-02-2017, 11:42
Rookie Year: 2017
How to send photo easily? Only link?
Unread 04-02-2017, 11:44
Originally Posted by serdaruluer View Post
Any.
The problem may be inadequate gear reduction.
But you need to provide more detail if you want more definitive help.
Describe the complete drivetrain from the CIM to the winch, including gear reductions, winch diameter, and rope diameter.
And post a couple of well-focused pictures.
You can attach them to your CD post, or you can upload them to imgur.com and provide links.
Unread 04-02-2017, 11:50
Rookie Year: 2017
https://drive.google.com/file/d/0B0L...ew?usp=sharing
Unread 04-02-2017, 11:53
Rookie Year: 2017
Unread 04-02-2017, 12:04
It looks like you have no gear reduction.
What is the diameter of the winch?
What is the diameter of your rope?
Unread 04-02-2017, 12:06
s_forbes's Avatar
That works, thanks!
It looks like you need a larger gear reduction than what you have right now. If you can put a gearbox between the CIM and the climbing shaft, then the climbing shaft will have more torque. This would probably work: http://www.andymark.com/ToughBox-p/am-toughbox.htm
I am not sure how long shipping takes to your part of the world. Do you have any other gearboxes, or know teams in your area that might have old gearboxes?
Unread 04-02-2017, 13:10
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
You will need a gear reduction of some sort. Our robot for 2016 used about a 35:1 gear reduction or so for our winch. We also used only one CIM and it worked perfectly fine for us. We usually were able to climb in about 4 to 5 seconds after the hook was put on the bar.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 04-02-2017, 13:16
Jacob Plicque Jacob Plicque is offline
FRC #0086 (Team Resistance)
Jacob Plicque is an unknown quantity at this point
A 12.75 GR AM Toughbox with a 150# robot, 2"dia winch, and a CIM motor will operate at over 60A of current. It is likely that a 40A breaker will trip during a 5 second climb. Try a GR ratio of ~25:1
Unread 04-02-2017, 13:19
The appropriate gear reduction depends on the winch diameter and -- in some designs -- on the rope diameter.
That's why I've asked the OP to tell us their winch diameter and rope diameter.
Unread 04-02-2017, 15:31
Rookie Year: 2017
Winch diameter is 3cm and rope diameter is 1,5cm.
Unread 04-02-2017, 15:36
Rookie Year: 2017
Can we find another solution but using gearbox? On the motor side small gear, on the shaft side big gear possible?
