I'm currently trying to program autonomous and it's working, I've isolated this issue to be with the Timer.Delay(seconds) command. When hovering over the command, it states that it allows: "Motors [to] continue to run at their last assigned values," but it simply stops them for the time allotted. Are there any alternative timing methods that allow motors to continue to run and change the command after an allotted time?
code:
case leftAuto:
System.out.print("YOU'RE LEFT");
Timer.delay(2.5);
arcadeDrive.drive(1, 0);
Timer.delay(5);
arcadeDrive.drive(0.75, .6);
Timer.delay(3);
solenoid2.set(DoubleSolenoid.Value.kForward);
Timer.delay(2);
solenoid2.set(DoubleSolenoid.Value.kReverse);
arcadeDrive.drive(-1, .8);
Timer.delay(4.8);
arcadeDrive.drive(-.25, 0);
Timer.delay(2);
break;
