Go to Post Failure is in my eyes, the key to success. If you can deal with failure, look it in the eye, and conquer it, the hard stuff won't really intimidate you any more...and you can only get better. - Andy Grady [more]
Unread 04-02-2017, 13:04
TeamImp219 TeamImp219 is offline
FRC #0219
TeamImp219 is an unknown quantity at this point
Router help
Hello, we just finished flashing and configuring a OM5P-AN router, and we are able to successfully deploy code by connecting the router to our RIO via tether, but we aren't able to interface with it to set static IP's. We need to do this because we are using opencv & python for vision processing which require static IP's. Does anyone know how to access the interface? Thanks a lot!
Unread 04-02-2017, 13:08
Re: Router help
The radio already has been given a static IP of 10.2.19.1 by the configuration utility.
This year the radio firmware does not include a web server, so you can't browse to it and change settings.
Unread 04-02-2017, 13:12
FRC #0219
Re: Router help
Ok thank you, so the only thing else we are confused with is setting static IP's for things like the raspberry pi?
Unread 09-02-2017, 22:53
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Router help
You have to set it as a static IP on the raspberry PI itself.
https://www.modmypi.com/blog/how-to-...address-update
