Go to Post Brace yourselves, reality check incoming. - EmileH [more]
Unread 04-02-2017, 16:28
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: 2.5" CIM Motor stops when climbing
Originally Posted by serdaruluer View Post
Can we find another solution but using gearbox? On the motor side small gear, on the shaft side big gear possible?
Based on the math I've done you need about a 9:1 ratio between the CIM motor and the spool (assuming a 1" diameter spool and a ratchet strap-style rope) to lift a fully loaded FRC robot with a decent margin of error (stalls at ~277lbs).
The biggest ratio you can get practically with sprockets (at least easily available ones) is about a 5:1. Now that said, at a 5:1 ratio, if you double the number of motors running it (like adding a second CIM to the opposite side of the system) that 5:1 ratio would work just fine.
Ideally though you would want a proper gearbox that will get you closer to that 9:1 ratio.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
