Go to Post To borrow a slogan from the last place KC Royals "It's Our Time" The curse will be broken! ;) - Alpha Beta [more]
Unread 04-02-2017, 15:46
michaelwm's Avatar
michaelwm michaelwm is offline
Integrated Systems Lead
AKA: Michael Midura
FRC #4976 (Rebel Robotics)
michaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the rough
roboRIO 2017 update over ethernet / SSH
One of our roboRIO's fried one day last year during an upload over USB-B. The cable started burning and the USB controller in the rio is now bricked. The ethernet port still worked though, so we were able to set the rio aside as a backup & testbench rio.
But now 2017 is here and we can't write 2017 WPILib software without updating the rio to the new 2017 image. We can't connect over USB-B, and we tried using ethernet and the NI roboRIO tool but that didn't work either.
Is there something else we can try? A different ethernet solution? SSH? Or is the rio garbage now?
Integrated Systems
Unread 04-02-2017, 16:33
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: roboRIO 2017 update over ethernet / SSH
What's your problem with the ethernet cord? That should work (it's what we used this year).
Also, if you have a fried RIO, contact NI. They are always extremely helpful to FIRST teams and will probably offer you a replacement at a reasonable cost.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 04-02-2017, 17:03
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
1. Make sure you set your computer to a static IP. The roboRIO doesn't run DHCP! Make sure you can ping the roboRIO
2. If you can ping the rio but the imager tool still doesn't work, try setting the roboRIO's ethernet interface to a static IP of 172.22.11.2 through the web dashboard so it might be able to pretend it's over USB
Worst that can happen is you brick your whole rio, so make sure you're ok with that
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 05-02-2017, 08:11
Only if your roboRIO is set static...otherwise you are setting your computer to a 10. while the roboRIO has a self assigned 169 address.
I would try placing a network switch between the roboRIO and the computer, especially if the roboRIO is set to DHCP. When the roboRIO reboots as part of the imaging process many computers will take too long to bring the network back up because they are trying to get an address.
It is also possible that you may see a failure near the very end of imaging even if the image has loaded. If the tool rescans and says that the image is 2017_v8 but the team number is blank, try just setting the team number and clicking Apply.
Unread 06-02-2017, 03:42
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
I meant that the rio doesn't run a DHCP server - so your laptop will not be assigned an IP address automatically
Unread 06-02-2017, 15:55
No, your laptop will self-assign a link local address, which is compatible with the link local address the roborio will self-assign. If you assign the computer a static ip address and the roborio uses a link local, it will never talk. If you assign both the roborio and computer compatible static ip addresses, it will work until the roborio reboots after loading the image, and assigns itself a link local address. This will probably show up as an imaging failure.
