Go to Post At this point (after shipping the robot), I'm really looking forward to doing laundry, eating a square meal, and getting to bed at a reasonable hour. - Emily Pease [more]
Unread 04-02-2017, 17:21
NicholasJJ NicholasJJ is offline
FRC #4014
NicholasJJ is an unknown quantity at this point
Question Robot takes a while to start up in autonomous mode
Hi, I'm having a bit of a problem with autonomous mode on my team's robot. after starting autonomous, the robot waits a few seconds and a bunch of these errors:
Error 1 Robot Drive... Output not updated often enough. java.lang.Thread.run(Thread.java.747)
show up on our drive station. After a while, the errors stop and the robot completes all the autonomous tasks perfectly fine. does anyone know how to solve this problem?
Unread 04-02-2017, 17:29
Re: Robot takes a while to start up in autonomous mode
Initializing a camera at the start of Autonomous might cause a blocking delay like that.
Unread 04-02-2017, 17:50
FRC #4014
Thanks, but our code doesn't have any camera initialization. We are initializing a Gyro, would that cause something like this?
Unread 04-02-2017, 17:52
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Yep. Gyro's have a 5sec blocking period when you initialize them.
Unread 04-02-2017, 17:54
I'd suggest commenting out all code leaving just enough to see that Auto is running and Teleop is running, then if the delay is gone just add things back in gradually to see when the delay reappears.
Initialize the gyro during Disabled.
Unread 04-02-2017, 18:53
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
I would recommend initializing the gyro during robotInit, otherwise the field might think you're ready and start a match before the gyro finishes initialization.
Unread 05-02-2017, 16:27
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Generally speaking, the best way to make sure the field knows you're not ready is to stand in your driver station holding a thumbs down in the glass. Often times, our field monitor may be completely green, but teams are still waiting for gyros, camera feeds, or some smart dashboard mess. A good FTA (which as far as I know is all FTAs) would see your thumbs down and would be able to assist before starting the match.
*A simple thumbs down is sufficient. No need to start banging that thumb into the glass unless a countdown to start match has begun.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 08-02-2017, 21:56
FRC #4014
Thanks for the help!
Turns out that a PID loop was causing the problem, I took it out and everything works fine now.
Unread 08-02-2017, 22:52
Thanks for letting us know how you fixed it.
