Go to Post How you say something is often just as important as what you say. - Rachel Lim [more]
Unread 04-02-2017, 17:58
arushshah1 arushshah1 is offline
FRC #6203
arushshah1 is an unknown quantity at this point
PID Loop Constants
I was browsing through the WPILib guide on PID Subsystems and I came upon this sample code:
public class Wrist extends PIDSubsystem { // This system extends PIDSubsystem
Victor motor = RobotMap.wristMotor;
AnalogInput pot = RobotMap.wristPot();
public Wrist() {
super("Wrist", 2.0, 0.0, 0.0);// The constructor passes a name for the subsystem and the P, I and D constants that are used when computing the motor output
setAbsoluteTolerance(0.05);
getPIDController().setContinuous(false);
I'm not sure why the code is setting the I and D constants to 0. Is it to only make it a P loop? Are there any benefits of using only P over PID?
Unread 04-02-2017, 18:22
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Re: PID Loop Constants
You are correct, setting the I and D constants to zero makes it a P controller rather than a PID controller.
To answer your question, sometimes a P loop is all that is needed to get the system behaving the way you need it(although usually at least the D constant is also required in FRC robots). It's important to note that when you are tuning a PID controller, you typically start with the P value and leave the I and D at 0. For more information about tuning a PID controller, I'd recommend this Wikipedia article as a starting point. It's not the only way to tune a PID controller by any means, but it is the most widely used.
Unread 04-02-2017, 18:24
FRC #6203
Great, thanks so much!
