Go to Post if it's likely to break, it probably will - DonRotolo [more]
Unread 04-02-2017, 21:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Left and Right Inverted on Joystick
Originally Posted by T8PineappleSam View Post
It is possible that the left and right ports for your speed controllers are mixed up. When you go forward and backwards (giving both sides the same input) this isn't apparent, but when you try to turn (giving one side more input than the other) the robot turns the opposite direction. I would recommend switching the left and right side ports and seeing if that fixes the problem.
+1: swapping left and right is so easy to do, and is so difficult to puzzle your way out of.
