Go to Post Where can I buy the awesomeness that you used on that? Do they sell it at andymark? - HansJ [more]
Unread 04-02-2017, 23:34
Re: Path Planning and Trajectory Troubles
Right and Left wheel traces.
Unread 05-02-2017, 15:00
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Here is what we found:
1. Our path planner is fine. We generated a path with the same inputs as antman, and our numbers are very close.
2. We executed antman's path file. Similarly to our file, the robot did not end up exactly where we wished.
3. We have lowered max velocity (as gerthworm suggested) and increased max jerk (from what we had) and are seeing improved accuracy. We are also getting less dispersion.
4. We are continuing to experiment with various values and tweaking based on better understanding of the center of rotation (per Jarod and Ether).
Thanks again to all.
