Our software is compatible, baby.
Unread 03-02-2017, 17:51
Lesafian Lesafian is offline
AKA: Jeremy Styma
FRC #6077 (Wiking Kujon)
Rookie Year: 2016
Lesafian is an unknown quantity at this point
Vision Processing ERROR: too many simultaneous streams
There's a problem with my vision code. I'm only using 1 output stream, but I'm getting the error "too many output streams". Here is my code
	// Vision Processing
	private VisionThread visionThread;
	private final Object imgLock = new Object();
	double centerX = 0.0;
	double width = 0.0;
	public String shotReady = "Shot Ready";
	int gripTolerance = 3;
	int tooFar = 90;
	int tooClose = 110;
	int camWidth = 320;
	int camHeight = 240;
	int imageCenter = (camWidth / 2);
	boolean isShotReady = false;
	VisionClass pipeline = new VisionClass();
	VisionRunner<?> visionRunner;
	UsbCamera cam0, cam1, selectedCam;
	Mat image;
	CvSink selectedVideo, gearVid, highGoalVid;
	CvSource outputStream;
	boolean isTargetFound = false;
	@Override
	public void robotInit() {
		// Switch Vision Targets
		cam0 = new UsbCamera("cam0", 0); // High Goal Camera
		cam1 = new UsbCamera("cam1", 1); // Gear Camera
		cam0.setResolution(camWidth, camHeight);
		cam1.setResolution(camWidth, camHeight);
		cam0.setFPS(16);
		cam1.setFPS(16);
		selectedCam = cam0;
		image = new Mat();
		// MjpegServer server = new MjpegServer("server", 1181);
		highGoalVid = CameraServer.getInstance().getVideo(cam0);
		highGoalVid.setEnabled(true);
		gearVid = CameraServer.getInstance().getVideo(cam1);
		gearVid.setEnabled(false);
		highGoalVid.grabFrame(image);
		selectedVideo = highGoalVid;
		outputStream = CameraServer.getInstance().putVideo("Selected Video", camWidth, camHeight);
		// server.setSource(outputStream);
		outputStream.putFrame(image);
		visionThread = new VisionThread(selectedCam, pipeline, pipeline -> {
			if (!pipeline.filterContoursOutput().isEmpty()) {
				isTargetFound = true;
				Rect r = Imgproc.boundingRect(pipeline.filterContoursOutput().get(0));
				Rect r1 = Imgproc.boundingRect(pipeline.filterContoursOutput().get(1));
				Mat processedImage = new Mat();
				synchronized (imgLock) {
					selectedVideo.grabFrame(processedImage);
					Imgproc.rectangle(processedImage, new Point(r.x, r.y), new Point(r.x + r.width, r.y + r.height),
							new Scalar(0, 0, 255), 2);
					Imgproc.rectangle(processedImage, new Point(r1.x, r1.y), new Point(r1.x + r1.width, r1.y + r1.height),
					outputStream.putFrame(processedImage);
			} else {
		visionThread.start();
Unread 05-02-2017, 10:05
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus of 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Re: Vision Processing ERROR: too many simultaneous streams
I had this problem even though the code was 100% correct. Rebooting the roboRIO while both webcams were plugged in fixed the issue.
FRC Drive: Play Store FRC Manager: Play Store
Unread 08-02-2017, 17:24
jwatson12 jwatson12 is offline
Mr. Watson
FRC #1025 (Impi Warriors)
jwatson12 is an unknown quantity at this point
Running into similar issue with two webcams. Rebooted Roborio with cams connected. Still get the same issue. How was this issue resolved?
Thanks
Unread 11-02-2017, 17:58
nomaxx117 nomaxx117 is offline
AKA: Noah
FRC #4786 (Nicolet FEAR)
nomaxx117 is an unknown quantity at this point
We are having this issue as well. What exactly trips this error? The piece of code that keeps breaking it for us simply creates an ArrayList of integers.
Unread 12-02-2017, 16:07
AKA: Jeremy Styma
Rookie Year: 2016
Thanks
After hours and hours of frustration, I believe the error occurs when either A) a frame is outputted at the same time, a cvSink grabs the same frame at the same time, or the CvSource does not output a new image.
If you're using a boolean to switch between camera streams in a thread, using a volatile boolean will prevent the thread from caching the original state of the boolean in order to save memory.
Could I see your source code?
(P.S, these are just my observations)
