Go to Post Maybe FIRST could get a sponsorship from Ikea, and we all could get flat-packed field parts with pictoral assembly instructions. And then all the parts could have funny names. - sanddrag [more]
Unread 04-02-2017, 18:09
Arod192's Avatar
Arod192 Arod192 is offline
AKA: Andrew Rodriguez | Koala
FRC #1972 (Searing Engineering)
Rookie Year: 2015
Arod192 is an unknown quantity at this point
We are trying to set up PID
This is the first year where we are
actually trying to do some of the more "complex" stuff. We are having a lot
of trouble with PID loops, attached are some pictures of our teleop and begin code.
Unread 04-02-2017, 18:24
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: We are trying to set up PID
P is proportional gain. That gain pushes back based on how far off you are. I is integral gain. It pushes back based on how long you've been how far away. Finally, D is derivative gain. It pushes back based on how fast you're going away.
In LabVIEW, it works a little weird, as you'll notice you have proportional gain, integral "time" and derivative "time." The way this works is that when you increase the P gain, all three gains are actually being increased, and the "time" values are multiplied by the P values to get their respective gain values (in a very weird way, there are extra multipliers in there, so don't go trying to figure out what your gains are, just roll with it)
You have to tune PID loops no matter what, it takes time, it's slightly dangerous (integral gain can run away from you fast, so have your hand on the E-stop), and honestly it's far from easy.
Good luck!
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 04-02-2017, 18:54
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
I am also part of this team. We understand the theory of the PID loop, but are having a hard time understanding if our application is correct. We have a PID loop to rotate the robot with a gyro to a set point and the PID works fine it that situation. At least with a tolerance of about 5 degrees. But getting the encoders to rotate at a constant speed is the issue. We are wondering, if there is an issue with how we are getting our rate. If our rate is outputting a value that makes sense. Why our PID loop does not reach our setpoint.
Unread 04-02-2017, 20:12
FRC #3007
Rookie Year: 2015
If your robot doesn't complete the movement, try raising your integral gain.
Team 3007: 2017
Unread 04-02-2017, 20:59
FRC #1972
The robot is not completing the ramp up to speed. This solution you have proposed is, if I understand correctly, helpful only if the motor does not have enough power to get up to speed. This is not the case as the robot is off the floor and the wheels are free spinning. As i increase the P value it climbs, but then begins to behave erraticly and the motor values jump quickly between 1 and -1.
Leave the P value at a value thay does produce erractic behavior, such as the value above, and increasing the I anywhere from 1000 to 1 will also produce erractic rate changes and sometimes stop producing a motor output.
Unread 05-02-2017, 11:47
FRC #3007
Rookie Year: 2015
1000 to 1? We're talking FRC robots in Labview here. The units on the I and D values are in minutes. It's really weird, I know.
Also, if the motor overshoots an oscillates, increase derivative gain.
Team 3007: 2017
Unread 05-02-2017, 13:31
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
As stated, the Labview PIDs are weird and, for us, have always defied tuning in a way that we understand.
Though you may not wish such a change, I have attached our PID VI. It has inputs consistent with common PID control practice (i.e. not coupled). It is a re-entrant VI so you can use it multiple times, and there are comment statements in it to explain its use, but feel free to PM me.
Unread 05-02-2017, 18:38
BitTwiddler's Avatar
BitTwiddler BitTwiddler is online now
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
We too are using PID this year and are having some luck with it for a change.
I've attached a couple of images of some helper VIs we created. The drive VI uses the NI LabView PID. We didn't have much luck controlling turns with it so we created our own PID using Proportional only. Seems to work pretty well too.
For driving we only use the encoders to tell us when to stop, the gyro works with PID to keep us going straight.
Unread 05-02-2017, 18:57
Looks nice.
Do you realize that the In Range and Coerce function has it's upper limit disabled (by default)? That's why it's a clear box, rather than a filled box like the lower limit has.
Right-click on the function and choose Include upper limit
Unread 05-02-2017, 19:37
AKA: Mr Tanguay
Originally Posted by Mark McLeod View Post
Looks nice.
Wow! As many times as I've used it I never noticed that. Something new every day.
