Go to Post Although I've never oxy welded myself, I know it is doable - jamie_1930 [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 27-01-2017, 09:53
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
2017 mjpg-streamer packages uploaded
Because cscore has been delayed more than I had anticipated, I've uploaded a build of mjpg-streamer. See https://github.com/robotpy/roborio-packages
mjpg-streamer is clunky to manage, and once cscore is available, you'll find that migrating to it from mjpg-streamer should be fairly straightforward and will offer a number of advantages (including integration with the default dashboards). But, this will get you going for now.
Unread 28-01-2017, 12:51
razar51 razar51 is offline
AKA: John Faulkner
FRC #1288 (Raven Robotics)
razar51 is an unknown quantity at this point
Re: 2017 mjpg-streamer packages uploaded
When I try to download it with the command:
C:\Users\Team1288\Desktop\robotpy-2017.0.6>py installer.py download-opkg mjpg-streamer
I get the error:
Traceback (most recent call last):
  File "installer.py", line 1009, in <module>
    retval = main()
  File "installer.py", line 990, in main
    retval = options.cmdobj(options)
  File "installer.py", line 792, in download_opkg
    package_list = opkg.resolve_pkg_deps(options.packages)
  File "installer.py", line 185, in resolve_pkg_deps
    for results in self._toposort(pkgs):
  File "installer.py", line 217, in _toposort
    raise ValueError('Cyclic dependencies exist among these items: {}'.format(', '.join(repr(x) for x in data.items())))
ValueError: Cyclic dependencies exist among these items: ('mjpg-streamer', {'libv4l'}), ('libv4l', {'media-ctl'}), ('media-ctl', {'libv4l'})
Unread 28-01-2017, 17:59
virtuald's Avatar
RobotPy Guy
I get the error:
    retval = main()
Heh, well that's annoying. The installer does a topological sort to figure out what items it should download and what order it should install them in... having a cycle makes that a bit annoying. I'll see if I can figure out a sane way to deal with this tonight.
Unread 28-01-2017, 23:04
virtuald's Avatar
RobotPy Guy
Try this installer: https://github.com/robotpy/robotpy-w...r/installer.py
Unread 31-01-2017, 19:56
AKA: John Faulkner
Originally Posted by virtuald View Post
works now.
C:\Users\Team1288\Desktop\robotpy-2017.0.6>py installer.py install-opkg mjpg-streamer
does not. media-ctl depends on libv4l and libv4l depends on media-ctl.
Copying over the opkg cache...
Looking up hostname roborio-1288-frc.local ...
Connecting to robot via SSH at roborio-1288-frc.local
Using username "admin".
NI Linux Real-Time (run mode)
Log in with your NI-Auth credentials.
Remote working directory is /home/admin
local:C:\Users\Team1288\Desktop\robotpy-2017.0.6\opkg_cache\install_opkg.sh => remote:/home/admin/opkg_cache/install_opkg.sh
libjpeg8 - 8d-r1.20
libjpeg8 already installed, continuing...
Collected errors:
 * satisfy_dependencies_for: Cannot satisfy the following dependencies for media-ctl:
 *      libv4l (>= 1.6.2) *
 * opkg_install_cmd: Cannot install package media-ctl.
Installing media-ctl (1.6.2-r0.3) on root.
Command '['C:\\Users\\Team1288\\Desktop\\robotpy-2017.0.6\\win32\\plink.exe', '-pw', '', 'admin@roborio-1288-frc.local', 'bash opkg_cache/install_opkg.sh']' returned non-zero exit status 255.
Unread 31-01-2017, 20:33
virtuald's Avatar
RobotPy Guy
works now.
libjpeg8 - 8d-r1.20
Collected errors:
Odd, it worked for me, but the problem is that the installer script installs each package separately... so it can't find the one that has the dependency cycle.
I would recommend just ssh'ing into the robot and installing the packages present in /home/admin/opkg_cache manually. Just run 'opkg install FOO.ipk'... you will probably have to specify libv4l and media-ctl at the same time.
Unread 04-02-2017, 23:03
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
We would love to get this installed, but the active install option seems to require an internet connection - how do we get our roboRIO connected to the internet? Do we just have to plug it into a router or something?
2014 IRI Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship Winners (Thanks 2052, 4778)
2014 Archimedes Quaterfinalists (Thanks 399, 2056, 2834)
2013 Minnesota State Championship Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
Unread 05-02-2017, 13:54
virtuald's Avatar
RobotPy Guy
robotpy-installer 2017.1.3 can correctly handle installing packages with cycles now (I even tested it with the roborio disconnected from the internet this time!).
bvisness: The robotpy installer can do offline installations, see the documentation for details.
http://robotpy.readthedocs.io/en/sta.../packages.html
Try it out and let me know. If the documentation sucks, let me know and I'll update it.
Unread 06-02-2017, 10:39
bvisness's Avatar
Thanks, we'll give that a try. Last time we tried the offline installation, the download step succeeded but the install step failed. (Same error as razar51.)
Thanks for your prompt fixes on this!
