Go to Post Crazy is relative - dtengineering [more]
Unread 04-02-2017, 14:23
wrightty wrightty is offline
FRC #6323
wrightty is an unknown quantity at this point
Error 1026 On Labview - Nothing works...
On our drivert station we have all green lights, comm, code, and joysticks. The joysticks are working according to the DS but it continuously gives us the following error
Error 1026: Property Node in FPGA_SystemAsync VI Agent.viLabVIEW: VI Revference is invalid.
No motors on our robot responds to the joysticks.
We don't know how to save our code as a single file so it can be posted (or backed up for that matter).
Any help would be appreciated.
Unread 04-02-2017, 16:56
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Re: Error 1026 On Labview - Nothing works...
Can you screenshot your teleop vi, and begin vi?
LabView saves under a directory, with the project file being the connector between all the vi's.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
Unread 04-02-2017, 17:01
The project folder is in Documents/LabVIEW Data/2017 Robot Project (or whatever name you gave your robot project).
I'd recommend position either a .zip of the whole folder or the .vi files themselves. Screenshots are less useful for locating typo errors.
Unread 05-02-2017, 15:02
FRC #6323
Thanks for the info on backing up the program and where to find the folder.
I'll post a .zip when I'm back at school tomorrow.
Unread 06-02-2017, 15:00
FRC #6323
Here is a link to a zip file of our labview program:
https://drive.google.com/file/d/0B4_...ew?usp=sharing
Just to reiterate, we are able to enable our robot but nothing moves when controllers are used (it should be driving arcade mode with 4 talons).
We are getting an error (see above) repeatedly in the driver station.
Thanks for any and all help.
Unread 06-02-2017, 15:50
In Begin you declare the same Talons multiple times.
I commented out all the Talons except for the four feeding Open 4 Motors.
Other than that, the code worked okay on my robot.
I don't get the FPGA_SystemAsync error, so that might be a corrupted roboRIO format.
You might try reformatting the roboRIO to see if that helps with the error.
P.S.
I forgot to mention that I used %V instead of Speed in Begin.vi to test with, since I didn't integrate encoders for feedback.
Unread 06-02-2017, 16:51
FRC #6323
Fantastic. Thanks for your help. I'll pass on the info to our programming group.
I appreciate the quick response.
Tyler
Unread 07-02-2017, 09:17
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Are you using CAN Talon SR's? IF you are, you have to go into the RoboRIO web interface and set your device IDs for the controllers. Leave indexes 0 and 1 open for the PCM and PDP, respectively.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 07-02-2017, 10:41
The indexes are device type independent, so we can have a PDP 1 and a PCM 1 and a Talon SRX 1.
They don't conflict unless they are the same type of device.
Unread 07-02-2017, 13:55
FRC #3007
Rookie Year: 2015
Oh. My bad then. It's good to know that now.
Team 3007: 2017
