Please Help Me!
I am programming LED's to be used alongside the RoboRio, with the Arduino to control them. But I am having issues. I need to use the I2C, I can not use the serial or other ports. I just cant get it to work! Here is the code I made for the Arduino: Code:
#include <Wire.h>
int serialData = 0;
int shouldChange = 0;
int SDI = 2; //Red wire (not the red 5V wire!)
int CKI = 3; //Green wire
int ledPin = 13; //On board LED
int a;
int b;
#define STRIP_LENGTH 84
long strip_colors[STRIP_LENGTH];
void setup() {
Wire.begin(8);
Wire.onReceive(receiveEvent);
Serial.begin(9600);
pinMode(SDI, OUTPUT);
pinMode(CKI, OUTPUT);
pinMode(ledPin, OUTPUT);
for (int x = 0; x < STRIP_LENGTH; x++){
strip_colors[x] = 0;
randomSeed(analogRead(0));
void loop() {
if (Serial.available() > 0){
serialData = Serial.read();
if (serialData == 1) {
setStripSolid(0x0000FF);
else {
setStripSolid(0);
delay (1000);
void receiveEvent(int howMany) { //called upon slave recieve
while(0 < Wire.available()) {
byte x = Wire.read();
Serial.println(x);
a = int(x);
while(1 < Wire.available()) {
byte y = Wire.read();
Serial.println(y);
b = int(y);
switch (a){
case 1:
switch (b){
case 1:
shouldChange = 1;
setStripSolid(0x0056e0); //auto mode blue
break;
case 2:
shouldChange = 1;
setStripSolid(0x15ff00); //teleop green
break;
case 3:
shouldChange = 1;
setStripSolid(0xfff600); //test yellow
break;
break;
case 2:
switch (b){
case 1:
shouldChange = 1;
rotateColor(0xe23804); //brown-out rotate red
break;
case 2:
shouldChange = 1; //idle sharp colors
sharpColors();
break;
break;
case 3:
switch (b) {
case 1:
shouldChange = 1; //gear orangy yellow
setStripSolid(0xffef11);
break;
case 2:
shouldChange = 1; //presure red solid for now
setStripSolid(0xff1111);
break;
case 3:
shouldChange = 1; //timer purple
setStripSolid(0xff11c3);
break;
void sharpColors() {
for(int x = STRIP_LENGTH; x > 0; x -= 5){
strip_colors[x] = 0xff7b00; //orange
strip_colors[x-1] = 0xff7b00; //orange
strip_colors[x-2] = 0x0033ff; //blue
strip_colors[x-3] = 0x41d12e; //green
strip_colors[x-4] = 0x41d12e; //green
void rotateColor(int color) { //will this work? WHO KNOWS!
shouldChange = 0;
while (shouldChange == 0) {
for(int x = STRIP_LENGTH; x > 0; x--){
strip_colors[x] = color;
post_frame();
for(int y = STRIP_LENGTH; y > 0; y--){
strip_colors[y] = 0;
post_frame();
void setStripSolid(int color) { //universal color feed, give hexidecimal. (0x...)
post_frame();
void post_frame (void) { //strip.show equivalent
//Each LED requires 24 bits of data
//MSB: R7, R6, R5..., G7, G6..., B7, B6... B0
//Once the 24 bits have been delivered, the IC immediately relays these bits to its neighbor
//Pulling the clock low for 500us or more causes the IC to post the data.
for(int LED_number = 0 ; LED_number < STRIP_LENGTH ; LED_number++) {
long this_led_color = strip_colors[LED_number]; //24 bits of color data
for(byte color_bit = 23 ; color_bit != 255 ; color_bit--) {
//Feed color bit 23 first (red data MSB)
digitalWrite(CKI, LOW); //Only change data when clock is low
long mask = 1L << color_bit;
//The 1'L' forces the 1 to start as a 32 bit number, otherwise it defaults to 16-bit.
if(this_led_color & mask)
digitalWrite(SDI, HIGH);
else
digitalWrite(SDI, LOW);
digitalWrite(CKI, HIGH); //Data is latched when clock goes high
//Pull clock low to put strip into reset/post mode
delayMicroseconds(500); //Wait for 500us to go into reset
And for the RoboRio: Code:
toSend[0] = 11; i2c.transaction(toSend, 1, null, 0); What am I doing wrong? I have looked around the internet and I can't find anything. If anyone has a tutorial or some example working code or can find something I did wrong, please let me know. I just don't know what to do! |
Re: I2C Connection Issues
Also, I don't know if I even connected it right. Is it even worth it to continue with i2c?
Are you allowed to use basic DIO?
I don't even know what that is
Digital Input/Output. Pins on the RIO that can be turned on and off as well as receive on/off signals, just like the digital pins on the Arduino.
How could I use that?
#7
Actually, I want to stick with i2c if possible
#8
DIO is possibly the easiest form of inter-processor communication.
#9
Take a look at how we accomplished this (in terms of code) here on our repo: https://github.com/FRC-Team-1403/RioDuinoIMUCode
