Go to Post Might change next year. Read the manual then too. - Billfred [more]
Unread 05-02-2017, 23:19
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Problem with initializing RobotDrive/Talon objects
If you are seeing "Error -52010 NIFPGA" in the Driver Station after adding a CANTalon, I would recommend reading section 16.36 in latest Talon SRX Software Reference Manual.
Unread 06-02-2017, 02:51
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
For the lazy
16.36. Adding CANTalon to my C++ FRC application causes the Driver Station log to report: ERROR -52010 NIFPGA: Resource not initialized, GetFPGATime, or similar.
A full example of the crashed call stack is below…
ERROR -52010 NIFPGA: Resource not initialized GetFPGATime
[Utility.cpp:171]
Error at GetFPGATime [Utility.cpp:171]: NIFPGA: Resource not initialized
at frc::GetFPGATime()
at frc::Timer::GetFPGATimestamp()
at frc::MotorSafetyHelper::MotorSafetyHelper(frc::MotorSafety*)
… this can happen if a CANTalon is constructed before the C++ WPILIB initialization routine is called. At the time of writing, this condition can occur when cleanly creating a C++ Command-based project with the latest Eclipse Plugins. An example workaround can be found here…
https://github.com/CrossTheRoadElec/...74df894f7bbf2d
…demonstrating how to ensure motor controller object is constructed after WPILIB initialization.
C++ Command-based projects generated with latest Robot Builder appears to ensure that motor controller objects are created after WPILIB initialization, and therefore do not cause this failure symptom.
More information on C++ Command-based projects can be found at the FRC screenstepslive page, as this is not maintained by CTRE. https://wpilib.screenstepslive.com
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 06-02-2017, 17:34
ozrien's Avatar
Omar Zrien
AKA: Omar
Originally Posted by euhlmann View Post
For the lazy
Hey that's cheating.
Unread 09-02-2017, 18:49
NStr NStr is offline
AKA: Nadav Strahilevitz
FRC #3835 (Vulcan)
Rookie Year: 2016
NStr is an unknown quantity at this point
Wasn't using Talon SRX but I guess the section applies to all Speed Controllers. Anyways this fixed the problem, so thanks a lot!
Unread 09-02-2017, 18:55
ozrien's Avatar
Omar Zrien
AKA: Omar
That's how good our support is.
