Go to Post Some of the best team captains I've seen have been from rookie teams. - Conor Ryan [more]
Unread 05-02-2017, 22:46
Kage2416 Kage2416 is offline
FRC #1546
Kage2416 is an unknown quantity at this point
Need help with coding issue
My team's robot has two different ways of scoring, one on one side, "the front", and one on the other side, "the back." The reason I put those in quotation marks is due to the fact that both sides may be considered the front of the robot. Our question is, how can we flip the coding of the robot so we can easily switch from one side of the robot being controlled by moving forward on the remote, to the other side being controlled like that. It's mainly so the drive team has an easier way of controlling the robot in the case that we cannot use one way to score. Any help would be appreciated.
Unread 05-02-2017, 22:51
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Need help with coding issue
You can simply have a command that just outputs a variable that switches between the straight output of your joystick or the reversed axis of your joystick that you want to oppose. Then plug this variable into your drive class.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 05-02-2017, 23:15
If it were tank drive, you'd need to switch the sides and the direction of the joystick axis.
Something like this:
Unread 06-02-2017, 07:37
FRC #1546
U/Mark McLeod sorry I don't know how to quote texts but is there any chance you could post the false version of the box in the code?
Unread 06-02-2017, 08:22
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
It should just be a pass through (without criss-crossing the lines). Because he posted a snippet, you should be able to download it and drop it back in LabVIEW and have it turn back into code.
Unread 06-02-2017, 09:25
That image is an actual code snippet.
Matthew took it and showed you the False case side.
It uncrosses the lines and are straight through otherwise.
To convert the image to code:
1) Save the image I posted to your desktop,
2) drag the image onto blank space in a block diagram
3) instant code and you can look at the False case directly.
To make your own snippets, highlight just the code you want, and choose Edit->Create VI Snippet from Selection
Unread 07-02-2017, 07:56
FRC #1546
Thank you all for your help with this. I will post back with results and more questions
Unread 08-02-2017, 10:45
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
As a fun snippet sidenote, I'm not sure if this is something related to me using Chrome or intended use. I don't need to save it. I just drag from Chrome over to my Block Diagram and it puts the code in place for me.
For completeness, you can tell the difference between a snippet and a screenshot by taking a look at the upper left corner. The awkward hand is shown to drag the code to your LabVIEW by the arrow. If you see that, it's a snippet.
