Go to Post I can't wait to be one of those old kids who can say "Yeah, I remember the days before districts." and then watch the kid's eyes widen when I explain the days of regionals.. - rachelholladay [more]
Unread 05-02-2017, 23:54
WSiggs WSiggs is offline
Pb Programmer
FRC #4908 (Dragons)
WSiggs is on a distinguished road
How to calculate target distance?
Our team is working on implementing vision processing, and we have rotation calculations down, but are unsure about how to approach calculating distance. I have seen that some people use a scale factor as a direct ratio between height of the target and that seems easy enough, but I have heard that this doesn't have the best properties (from 254). They recommend using "line - plane intersections", but I have had trouble finding some examples of this. Where would I be able to find examples of these calculations? And are there any other better ways to calculate distance?
Unread 06-02-2017, 02:14
AriMindell AriMindell is offline
FRC #1389 (The Body Electric)
Rookie Year: 2015
AriMindell will become famous soon enoughAriMindell will become famous soon enough
Re: How to calculate target distance?
We are using an ultrasonic sensor to determine range from the target, since I believe using the vision itself to determine range is less reliable/accurate. That said, if you are still interested in doing it with vision, GeeTwo gave a good answer to this in another thread:
Originally Posted by GeeTwo View Post
If you're asking what I think you're asking, use the height of the retroreflective area. Its actual height 5". Divide that by the number of pixels of its height, and you have a good estimate of the image resolution in a direction perpendicular to a (presumably horizontal) camera, and can roughly calculate range.
Alternately, just measure the height in pixels (P0) at a known range R0 (say 10 feet). Then whenever you're looking at the target, R = R0 * P0 / P. Should be close enough to get you going, but it breaks down as you get close to the target and the sine of the angle is no longer proportional to the angle.
Unread 06-02-2017, 02:40
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Last year we calculated distance and angle based on the x/y position of the target in the image and it worked pretty well.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 06-02-2017, 07:11
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge will become famous soon enough
If you know the FOV of your camera in degrees, pixel resolution of the image and the real-world dimensions of the target, then you can compute the distance.
This page should get you going. Especially the "Measurements" section about half-way down.
Identifying and Processing the Targets
Unread 06-02-2017, 09:29
FuzzyLogic FuzzyLogic is offline
FRC #3792 (Army Ants)
Rookie Year: 2016
FuzzyLogic is an unknown quantity at this point
Another way to calculate distance is to look at the height of the object within a the camera's field of view. Very close to the tower the vision target is at the top of the image, and as you back up it lowers to the middle of the image.
You can either use an empirical function to determine distance (beware, it's not linear though) or use geometry. Our team uses geometry and it's been pretty successful. We typically calculate within 1-3 inches of the actual distance.
This method is also easy to calibrate. Although the pixels-to-distance function isn't linear, the error in the calculation is. Finding the slope of the line allows you to adjust the angle constant in the formula.
