Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Unread 06-02-2017, 09:53
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Thunderhex and Thunderhex Bearings
Has anyone else seen fitment issues with the Thunderhex and the Thunderhex bearings after you tapped the end of the shaft. Another mentor brought this to my attention. The thought is the end of the Thunderhex shaft is deforming out when tapped which causes issues in trying to install it into the Thunderhex bearing. The mentor plans to try Hex bearings, but I think he will have the same issue.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 06-02-2017, 09:57
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
Re: Thunderhex and Thunderhex Bearings
Take the Thunderhex and clamp it in a drill. Then take sand paper and wrap it around the Thunderhex. Spin the Thunderhex while moving the sand paper up and down it. It will wear away the paint on the rounded edges making it easier to fit in the bearing.
Team 3260 SHARP
"Success is never final, failure is never fatal, its the courage that counts"
~Luke
Unread 06-02-2017, 09:59
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I did notice last week that one of our shafts was a little harder to get in the bearing than I expected, and we had tapped that end of the shaft. It still fit, though, so I didn't really think much of it.
Try taking a file to the end of the shaft. Maybe there's a small burr there from cutting the shaft?
2016: Lake Superior WFFA
Unread 06-02-2017, 10:02
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
This warning is in red on the thunderhex page itself
Note: Due to a manufacturing variance, our current inventory is slightly out of tolerance. The diameter of our ThunderHex Stock is oversized by (on average) 0.0003". This results in a press-fit into ThunderHex round bearings. Users who need a looser fit should gently sand the rounded corners of the hex.
Unread 06-02-2017, 10:04
Mentor,QCR Planning
I'm assuming the removed burrs, but will check tonight and will have them try sanding them down. Some of the shafts are long, so we will probably clamp in our lathe and run some emery cloth on them.
Thanks!
Unread 06-02-2017, 10:05
Mentor,QCR Planning
Isn't that an old warning from last year? When our bearings and shaft first arrived we checked the fitment and it was smooth. So thats why we suspected the tapping operation.
Unread 06-02-2017, 10:13
gigaphoton gigaphoton is offline
FRC #3042
gigaphoton is an unknown quantity at this point
Our team has always had issues with the thunderhex being oversize enough where bearings, sprockets, ect won't slide on easily. As others have said, take some sand paper and put it in a drill to remove some of the paint. This usually lakes care of it, but sometimes you have to file down the actual sides.
Unread 06-02-2017, 10:17
Mentor,QCR Planning
Thank you!
Unread 06-02-2017, 10:28
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
Because of these issues our team has stopped using thunderhex as axles, only using leftover materials as cool-looking standoffs.
Last year was thunderhex hell for our team
2014: FRC 2169 scouting/spirit, FTC 7897 Mechanical
2015: FRC 2169 Mechanical/CAD
2016: FRC 2169 Mechanical/CAD
2017: FRC 2169 Head of Mechanical
Unread 06-02-2017, 10:44
Mentor,QCR Planning
Have you found another option when using hex shaft? We bought some from McMaster-Carr last year and had issues with the tolerance on it vs. the tolerance of the Hex Bearings and had an extremely difficult time installing the shafts on our climber. So we decided to go with the Thunderhex this year.
Harrison.Smith Harrison.Smith is offline
Business, CAD, Mechanical
Harrison.Smith has a spectacular aura aboutHarrison.Smith has a spectacular aura about
Last year we almost always used thunderhex axle with regular hex bearings. This allowed for the ease of tapping but also an easier operation of getting the shaft into the bearing.
“Rest and be thankful.” — William Wadsworth
Team 1296: 2014 - 2016
Unread 06-02-2017, 10:46
Mentor,QCR Planning
Thanks we plan on testing the regular hex bearings tonight to see if their is a difference.
Unread 06-02-2017, 10:52
Mentor, LRI, MN RPC
Personally, I think dealing with Thunderhex being a little oversized is a lot easier than dealing with regular hex being oversized. At least with Thunderhex we can toss it on the lathe and take a couple thou off, and once you dial in the amount you need, it's pretty easy to run down an entire shaft. Heck, in the few cases where we feel a need to use solid hex (instead of Thunderhex with the hole in the middle), we turn it down to fit in thunderhex bearings. It's just easier to slide the shafts in and out of thunderhext than it is trying to get the shaft prperly aligned with the inner race of a hex bearing.
Unread 06-02-2017, 11:03
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
We haven't noticed any fitment issues after tapping our thunderhex, but it certainly seems possible. What size tap are you running, 1/4-20?
The batch of thunderhex we bought before this preseason had no fitment issues, we love it.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 06-02-2017, 11:04
Mentor,QCR Planning
-Mike
Yes it is 1/4-20. No issues seen before tapping, but was found after.
