Go to Post Life is more fun if you take some risks every so often. - Andy Baker [more]
Unread 06-02-2017, 12:19
Pikaton659 Pikaton659 is offline
Pikaton659 is an unknown quantity at this point
Trouble With Variables
I should start off by saying I started this season with no experience in programming and thus learned all I know form the FRC website so please try to answer in easy to understand terms if you can. Anyway, I am trying to make a varying shooter for shooting balls and I use the variable x and when I hit the button it doesn't work. I have tried using a basic number value and it does so it has to be an issue with the variable. Here is the code:
#include <WPILib.h>
* This is a demo program showing the use of the RobotDrive class.
* The SampleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
* WARNING: While it may look like a good choice to use for your code if you're inexperienced,
* don't. Unless you know what you are doing, complex code will be much more difficult under
* this system. Use IterativeRobot or Command-Based instead if you're new.
class Robot: public frc::SampleRobot {
frc::RobotDrive myRobot { 0, 1 }; // robot drive system
frc::Joystick stick { 0 }; // only joystick
public:
Robot() {
myRobot.SetExpiration(0.1);
void OperatorControl() {
int x = .50;
Talon *exampleTalon = new Talon(4);
int buttonValue0 = stick.GetRawButton(1);
int buttonValue1 = stick.GetRawButton(2);
int buttonValue2 = stick.GetRawButton(3);
while (IsOperatorControl() && IsEnabled()) {
myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
frc::Wait(0.005); // wait for a motor update time
if (x <= 1.0 and buttonValue0 == 1)
x = x + 0.005;
//frc::Wait(0.005);
if (x >= 0.0 and buttonValue1 == 1)
x = x - 0.005;
//frc::Wait(0.005);
if(buttonValue2 == 1)
exampleTalon->Set(x);
START_ROBOT_CLASS(Robot)
Any help would be greatly appreciated.
Unread 06-02-2017, 12:25
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Trouble With Variables
If you're new to programming, you should really use RobotBuilder. It'll do all the hard work for you.
Here's the documentation
WPILib
GRIP, RobotBuilder
Unread 06-02-2017, 12:56
I tried Robot Builder but it seemed more confusing than the normal one. I also said it weird in my post above; I meant to say that I have some programming experience just never for FRC or this C++.
Unread 06-02-2017, 23:23
BrianK BrianK is offline
FRC #1622
BrianK is an unknown quantity at this point
You are attempting to assign floating point values to an integer.
Unread 07-02-2017, 11:50
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Time for a repost:
Originally Posted by euhlmann View Post
The number of teams I've been seeing this season on CD who are using C++ but need help with basic WPILib tasks is really frightening.
If you need help [with such tasks], you're going to have a lot of fun with manual memory management, segfaults, the cryptic error messages from GCC...
Please consider switching to Java or LabVIEW
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
