Go to Post Life isn't a set track: you have to go out and make your own path. - Greg Marra [more]
Unread 06-02-2017, 12:32
WalnutsAndBolts WalnutsAndBolts is offline
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Exclamation Help Programming Labview
Hi,
I need to program one piston. My compressor works.
Could I see a picture your labview code for the solenoids? Do you have it so that when you hit a button on the controller that the piston goes out, and the goes back in when you hit another button?
Unread 06-02-2017, 12:34
ethan271's Avatar
ethan271 ethan271 is offline
FRC #0935 (Railerobotics)
Rookie Year: 2015
ethan271 is an unknown quantity at this point
Re: Help Programming Labview
Something you might do it look in the examples and see the compressor w/ solenoid. That might help
01010111011010010111001101101000001000000111010101 11001100100000011011000111010101100011011010110010 0001
Unread 06-02-2017, 12:38
Rookie Year: 2017
I can't seem to find it. Can you find a link?
Unread 06-02-2017, 13:36
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
If I remember correctly, you'll want to open your code project and then click the "Help" drop down box in the toolbar. There should be an option named "Find LabVIEW Examples.." Once you click on that, you can search for examples with the context menu that pops up.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 06-02-2017, 15:20
jojoguy10's Avatar
jojoguy10 jojoguy10 is online now
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Team 358 has a TON of great LabVIEW snippets on their website: http://www.team358.org/files/program...view/index.php
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
