Go to Post the always so humble metal-in-motion.....i know your tricks; you all are gonna have a killer robot as usual.... - Stephen Kowski [more]
Unread 06-02-2017, 11:07
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Thunderhex and Thunderhex Bearings
Originally Posted by Jon Stratis View Post
Personally, I think dealing with Thunderhex being a little oversized is a lot easier than dealing with regular hex being oversized. At least with Thunderhex we can toss it on the lathe and take a couple thou off, and once you dial in the amount you need, it's pretty easy to run down an entire shaft. Heck, in the few cases where we feel a need to use solid hex (instead of Thunderhex with the hole in the middle), we turn it down to fit in thunderhex bearings. It's just easier to slide the shafts in and out of thunderhext than it is trying to get the shaft prperly aligned with the inner race of a hex bearing.
I agree
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 06-02-2017, 12:05
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Jimmy Nichols View Post
Isn't that an old warning from last year? When our bearings and shaft first arrived we checked the fitment and it was smooth. So thats why we suspected the tapping operation.
Just throwing this out there - when your shafts arrived, were they left outside in the cold before opening? The tolerance is so close that a shaft below room temperature will smoothly fit, but they will be too tight if you don't do that.
Anyhow, for us it's now a standard practice to take some emory cloth and shaft stock and run it on the lathe for a second or two before fitting into bearings. Just enough to strip the anodize layer off should do it. (We also use the "tight press" bearings because they are so cheap in 11-packs)
ThunderHex is way, way, way better than regular hex. I'll never go back to regular hex bearings - they are a pain to fit, a pain to align, and they are far harder to fix the shaft for if they fit too tightly.
Unread 06-02-2017, 12:08
Mentor,QCR Planning
They were not left outside.
Thanks for the feedback. I'm leaning this way myself. Hearing confirmation from others is re-assuring.
Unread 06-02-2017, 12:29
RoboChair's Avatar
AKA: Devin Castellucci
I have used shrinking to fit thunderhex into bearings before. I used liquid nitrogen(-320 F) to do it, but dry ice(-109 F) should do just fine and a lot of grocery stores carry it.
Aluminum shrinks/expands ~0.001"-0.0015" per inch per 100 degrees F, which you can get about 1 thou shrink with dry ice or about 2 with liquid nitrogen.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 06-02-2017, 12:32
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
Have you found another option when using hex shaft? We bought some from McMaster-Carr last year and had issues with the tolerance on it vs. the tolerance of the Hex Bearings and had an extremely difficult time installing the shafts on our climber. So we decided to go with the Thunderhex this year.
Andymark offers 7075 hex shaft that our team now uses for drivetrain axles (but works for anything else). If anything, however, this shaft is a little too thin. There's a small degree of play in our wheels that are mounted on it, but we haven't noticed a loss in performance as a result.
It could even just be our wheels too. I've been too busy with other parts of the robot to address the seemingly trivial problem that is axle size. We're just happy we didn't need to slice of faces of the shaft on a mill this year
We also get hex shaft from a local metals warehouse, Discount Steel. They may or may not ship to your area... but if you have a local metals warehouse I'd imagine they would have hex shaft. If you do have a shop nearby bring hex bearings and test them on the shafts before you buy them
2014: FRC 2169 scouting/spirit, FTC 7897 Mechanical
2015: FRC 2169 Mechanical/CAD
2016: FRC 2169 Mechanical/CAD
2017: FRC 2169 Head of Mechanical
Unread 06-02-2017, 12:50
Mentor,QCR Planning
We bought hex shaft from McMaster-Carr last year and the tolerances were horrible the hex bearings wouldn't fit at all and we machined and/or sanded the surfaces. We switched to Thunderhex and decided to use it again this year. We Metal Supermarkets locally, but I haven't tried to source any hex from them before. May try that in the off-season to see what kind of pricing we can get.
Thanks!
Unread 06-02-2017, 13:12
ClockworkGold's Avatar
ClockworkGold ClockworkGold is offline
Wears Sparkly Gold Pants
AKA: Andrew F.
ClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to behold
Hate to break it to you Matt, but I spent all of yesterday flycutting our intake axles
To all the teams struggling with hex shaft and bearings, here are some tips I've accumulated over the past year on the subject:
  • According to our civil engineer and machine shop specialist mentor, "0.002 inches isn't a press fit, it's a miss." Physically go to your local metal supplier with a caliper, a few new bearings, a rag, and some carburetor or brake cleaner to wide off any excess dirt or grease that may be on the stock. Hex is cheap, about $0.80/foot so loading up on up to 60 feet is a great idea if you're building two robots like a lot of teams are. Just remember, if it's not perfect, then it's absolutley not worth the hassle.
  • ThunderHex does indeed work with half inch hex applications, except post 2015 hex bearings. If you want to power ThunderHex in a live axle scenario without an assembly headache, you need P/N: 217-4006 or 217-4270.
2014: FRC 2169 Scouting and Spirit & FTC 7897 CAD
2015: FRC 2169 CAD, Strategy, Scouting & FTC Mentor 3385, 3387, 4509, 7899, 7900
Last edited by ClockworkGold : 06-02-2017 at 13:36. Reason: More bearing information, also spelled carburetor wrong
Unread 06-02-2017, 14:03
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
This will be our 3rd year using thunderhex. All of our old stock had to be polished to fit bearings. The new stock from this year seems to fit fine.
If the bearings fit before tapping then don’t after tapping, the tap needs thrown away. The tap is deforming the material not cutting it. Anodize is very abrasive on cutting tools.
Mr. Mike
Unread 06-02-2017, 14:08
Mentor,QCR Planning
Mr. Mike
Interesting. I wasn't involved in the making of the parts. only hearing about it since I am the person who orders the parts and was warned they may want to replace all the bearings we just ordered. So I will bring this up also. Thanks Mike!
Unread 06-02-2017, 14:16
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Thanks!
You are never going to find hex at your local metal supplier that will be toleranced such that you do not have these issues.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-02-2017, 14:25
Mentor,QCR Planning
Based on our experience last year, this year, and reading others. I think you need to use the Thunderhex bearings, always. You can always throw any hex you have on the lathe and turn it down or sand it down to the 13.75 or 13.73 mm you need.
Unread 06-02-2017, 14:33
krtanjek's Avatar
krtanjek krtanjek is offline
AKA: Donnie Krtanjek
FRC #0225 (TechFire 225)
krtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud ofkrtanjek has much to be proud of
Yes it is 1/4-20. No issues seen before tapping, but was found after.
Out of curiosity, did you drill the thunderhex prior to tapping 1/4-20 with a #7 Drill bit?
We have old and new Thunderhex and if you do not drill out prior to tapping we have seen it expand, but not if we drill out with #7 before tapping.
Unread 06-02-2017, 14:45
Mentor,QCR Planning
I wasn't directly involved but was only brought in after the fact. My assumption is they did not drill it out for a number 7 but instead tap it since the website advertises the hole as being ready to tap.
All the Thunderhex being used was purchased this season.
Unread 06-02-2017, 14:56
krtanjek's Avatar
I would drill it out with #7 and compare, we like to make sure all holes are at least #7 before using the 1/4-20 tap. Good luck.
Unread 06-02-2017, 15:03
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
We broke 2 taps before realizing that the hole on the new TH was not to size. Serves us right not checking before hand. The last few axles we did drill out with the correct drill bit before tapping and it was a breeze. While this year's TH shafting has the issue with the center hole, the outer dimensions are perfect so far...the flats fit to 1/2" width and the rounded corners fit inside the TH bearings without needing to file.
FRC78: 2010-Present
FRC121: 2002-2009
