Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 06-02-2017, 14:24
trycatch's Avatar
trycatch trycatch is offline
FRC #5858
Rookie Year: 2015
trycatch is on a distinguished road
Re: How do you shoot so fast?
What are you using to add mass to the wheel? We're using a pneumatic wheel... I guess we could add weight to the hub somehow..
Unread 06-02-2017, 14:30
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Keep in mind that the further the mass is from the center of rotation the more effective it is (if my memory of physics is correct anyways).
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 06-02-2017, 14:43
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Originally Posted by JCharlton View Post
Another thing to consider is reducing the amount of energy lost per ball. If your system compresses the ball a lot during a launch, more energy will be lost - which needs to be replaced.
I'll second this. Our initial prototype would audibly slow down when we shot a single ball because we had too much compression involved. With our final design, we have less compression on the ball and a more compliant shooter wheel. I don't think we've done the PID loop for it yet (waiting for some new sprockets to get in so we can test different ratios), but we can gravity feed in a line of balls (maybe 5 balls/second) with no noticeable change in the wheel speed or power of the shot.
2016: Lake Superior WFFA
Unread 06-02-2017, 15:08
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
A note on using the TalonSRX for FPID control. You need to use an encoder with enough ticks to give you a high enough resolution to get good feedback. The more ticks you can fit into the 100ms velocity read the higher the resolution you will have.
Unread 06-02-2017, 15:12
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
A good way is just to add something with more mass to the drive shaft. I have seen some robots that just bore out a piece of solid stock and put that on the driveshaft. Another option might be to use something like an AM performance wheel (made of aluminum, mass is further away from the center).
In a physical sense, you are trying to increase the mass moment of inertia of the shaft driving your shooter (or another shaft in the system), such that the entire system has a greater angular momentum while at the desired operating speed. Assuming that in all cases the fuel is being launched in an identical way, the impulse that the shooter will impart on the ball (impulse is a force over a given time, or alternatively an acceleration over a given time), each fuel fired should "take away" a constant amount of angular momentum away from the system.
Now, here's the fun part. As you increase the mass moment of inertia of your system, you increase its angular momentum at the operating speed. So, when you fire a fuel out of your shooter, that loss in momentum (the impulse applied to the fuel) is a smaller fraction of the total momentum. So, the angular speed (the rpm's) of your system will decrease by a lesser amount. This means that the system is closer to the operating speed after firing a fuel.
To get back to operating speed, the motor has to apply the same energy in all cases, because the fuel still left with the same energy it did is the previous case (neglecting friction because hopefully you used decent bearings). HOWEVER, since your speed loss was less because the fraction of angular momentum lost was less compared to the overall angular momentum of the system, the chances are that your system is closer to or still within the tolerance range for acceptable shooter speeds to reach your target (ie. you can still make your shots because your rpm's only changed a little). So, by increasing the rotational inertia of your system, the speed will decrease less per shot, meaning you can make more shots more quickly while holding your speed within the appropriate ranges.
Now, you still will lose some speed after every shot. This is why you need to design your system such that, after a shot, the controller (probably a PID loop on a Talon) can add more power to the system. By gearing so that the right speed comes at ~50% (plus or minus a bunch depending on your taste) the maximum speed, when fuel is fired, there is more overhead for available power from the motor to be delivered to the system, so you can recover more quickly. Additionally, if you design to run at 100% speed, you run into issues where battery voltage and draw from other robot systems might prevent you from ever reaching your target speed.
So, back to your question of how to add mass (increase inertia):
Add something with mass to a spinning part of the system (think flywheel). As you add mass, the system will take longer to reach speed ("spin up"), but once there, it will remain at speed for a longer time (all the discussion above about momentum). If you are driving the system with something like a VP, the only real place to add mass is on the main output shaft. However, if you are doing a custom system, or have a stage after the planetary like a chain reduction, you could also add more mass before the final stage. The faster it spins, the more inertia it has, so by adding mass to an earlier stage in the system, you can theoretically get more bang for your buck by increasing momentum more while allocating less of your robot's weight to the flywheel. Also, something like a performance wheel is great because the mass is farther from the rotational axis, so its inertia is greater than just a simple hub, even though they have the same mass.
Another thing: be safe. Think about where the mass is located. Can it grab someone's finger? Is the shaft it is spinning on well supported so that the spinning mass doesn't fly apart? Is this much angular momentum safe (see all the spinning Battlebots that are basically gyroscopes that fly all over the place when disturbed)? Is the torque required on startup to great for the motors being used (it is probably possible to have too much mass)?
OK that's a lot of words.
tl:dr;
-spin up as much mass, located as far from the rotational axis as possible, as fast as possible (without creating a spinning death machine).
-gear smart so you have more power available to recover speed lost to firing fuel
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 06-02-2017, 15:16
Jared Russell's Avatar
Taking a year (mostly) off
Here's a Pro Tip: Take a look at the latest Talon SRX firmware release notes.
Unread 06-02-2017, 15:25
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by rich2202 View Post
The motor stays the same. It is the addition of the flywheel that matters.
Let's say that the wheel is spinning at 600 rpms, and declines to 550 rpms after a shot. You have to wait for the wheel to spin back up to speed.
After adding the flywheel, the 600 rpms delines to 590 rpms after a shot. The motor then goes to 100% to speed back up to 600 rpms. You can then shoot as fast as the motor can deliver energy to the system.
That is not exactly correct. Technically a ball removes the same amount of energy from a high or low inertia system and it will take the same amount of power to get it back to the original state.
The advantage of more rotational inertia is that a single ball will lower the RPM by a smaller amount. Assuming you've engineered your system to have a window of RPM's you can make a shot in, the higher rotational inertia will end up giving your system more time to react to the loss of energy. That is the key.
1. Your rotational inertia should be high enough that you can shoot more than 1 ball without dropping out of your acceptable window.
2. This allows the system enough time to react and ramp up the motor power to compensate and keep the system inside the window.
Unread 06-02-2017, 15:27
Tom Line's Avatar
The ones that allow for you to change the number of averaging samples to provide the talon with a faster speed update rate? That one?
