Go to Post You know what they call the graduate with the lowest GPA in med school? Doctor. You know what they call the fourth robot in the alliance that wins Einstein? Champion. - Billfred [more]
Unread 30-01-2017, 16:55
michael3102 michael3102 is offline
FRC #3102
michael3102 is an unknown quantity at this point
FRC targeting light questions
Is the am-3418 FRC targeting light from AndyMark legal and where does it plug in?
Unread 30-01-2017, 17:01
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: FRC targeting light questions
Yes, it's legal. HOWEVER, it's very bright. So, while it can be powered from a 20A breaker on the PDP, your inspectors will likely require you to be able to turn it off when not using it to aim in order to avoid blinding people. So, put it on a Spike relay and you'll be pretty safe. Even better, keep it pointed low so it doesn't shine in anyone's field of vision!
I think the benefit to these lights is a little less this year, as the Boiler is in the corner with your own alliance station. The tight angle to see where it's pointing makes it less valuable for use there. Using it to line up with the gear slot is possible, but I'm not sure it would be very helpful there, as that's a close-in thing, not a long-distance shot.
2016: Lake Superior WFFA
Unread 30-01-2017, 17:27
FRC #3102
Where does a LED light ring plug in? https://www.superbrightleds.com/cat/...accent-lights/
Unread 30-01-2017, 17:29
Mentor, LRI, MN RPC
Your link doesn't seem to be working. But if it's a 12V automotive light ring, then the answer is the same. It can go off a 20A breaker, but if it's too bright you'll be asked to control it with a relay.
Unread 30-01-2017, 17:46
FRC #3102
Since spike is discontinued can I use anything else instead?
Unread 30-01-2017, 18:11
Mentor, LRI, MN RPC
An LED light is considered a CUSTOM CIRCUIT, so those rules apply. You can use pretty much any appropriate relay in a CUSTOM CIRCUIT.
Unread 01-02-2017, 09:51
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
I still think it would be best to buy a Spike off an older team.
Also, when you code this (assuming you're in LabVIEW), you can use the Enable Vision global variable to control the relay in Periodic Tasks.vi, but make sure to remove the Enable Vision code from Robot Main.vi, because if you don't remove that and try to set the variable somewhere else (like controlling it with a button in Teleop) it can and will cause a race condition.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 06-02-2017, 13:29
mbowdich mbowdich is offline
FRC #3302
mbowdich is an unknown quantity at this point
We ran one off of a Victor controller in 2012, which gave us the ability to control the intensity.
Unread 06-02-2017, 13:31
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Great, where can I buy one?
Unread 06-02-2017, 13:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As this is a custom circuit, a 12V relay module can be controlled from a relay port or a DIO. (Similar products are available from many different vendors.)
Unread 06-02-2017, 16:24
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If it is a low enough current draw, you can also try using the pneumatic control module directly.
Unread 06-02-2017, 20:11
FRC #3007
Rookie Year: 2015
Yes, but not in a way that is within the rules.
Team 3007: 2017
Unread 06-02-2017, 20:15
R35 Custom Circuits are allowed to be connected to the PCM, 1 per channel
Unread 06-02-2017, 22:08
FRC #3302
If you are using the targeting light from AndyMark, you cannot connect it to the PCM. It draws 1A and the PCM is only good for 500mA.
