Go to Post I once started to build a time machine. But then I went back in time and told myself that it wouldn't work, so I gave up on it. -dave - dlavery [more]
Unread 06-02-2017, 16:40
Maju Maju is offline
FRC #1382
Maju is an unknown quantity at this point
Bumper
Parts of the robot can stand up to the outer perimeter or just the inside of the bumper?
Thanks All
Unread 06-02-2017, 16:43
RoboChair's Avatar
AKA: Devin Castellucci
Re: Bumper
Thanks All
Everything must START inside of the bumpers. But after the match starts your robot may expand to occupy the full volume you have chosen.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 06-02-2017, 16:44
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Bumper
When starting, everything must be inside the bumpers and max height.
R02. In the STARTING CONFIGURATION (the physical configuration in which a ROBOT starts a MATCH), no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, with the exception of its BUMPERS and minor protrusions such as bolt heads, fastener ends, rivets, etc.
Once the match has started, everything must stay within the volume limitation
R03. Maximum ROBOT size, including BUMPERS and all extensions, must be constrained to one of two volumes:
A. 36 in. by 40 in. by 24 in. tall (~91 cm by 101 cm by 60 cm tall).
B. 30 in. by 32 in. by 36 in. tall (~76 cm by 81 cm by 91 cm tall).
The ROBOT must remain constrained to the maximum inspected volume at all times during the MATCH (i.e. A ROBOT may not switch between volume A and volume B without being re-inspected).
Unread 06-02-2017, 16:54
pmattin5459 pmattin5459 is online now
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Re: Bumper
Also, search is your best friend. There have been multiple threads on this subject, plus Andy from AndyMark made a contest for videos to explain this exact subject.
Unread 06-02-2017, 23:52
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Re: Bumper
Just to be picky about it (the way your LRI will do), everything must be inside the frame perimeter at the start of each match. Since there can be some small gaps behind parts of the bumper, the frame perimeter and not the bumpers should be used as the datum.
Your Robot Inspector will look for your robot's ability to keep all appendages inside the frame perimeter with the bumpers off, if he is doing a good inspection job!
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
