Go to Post FIRST isn't about the money. It is about the experience. - dubious elise [more]
Unread 06-02-2017, 14:42
philmharner philmharner is offline
FRC #5243
philmharner is an unknown quantity at this point
CAN Talon SRX Programming
Hello, programming in Java and my entire team is unable to find any way to code these talons. ScreenStepsLive said that we could use external jars, from http://www.ctr-electronics.com/hro.h...ical_resources
We got the external jar, imported the CTRLib.jar into eclipse.
Image. Error on the bottom. CrossTheRoad Library on the left.
http://i.imgur.com/jlLfXQe.png
Github: https://github.com/CentrevilleRobotics/Steamworks
Error:
java.lang.UnsatisfiedLinkError: no CTRLibDriver in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1857)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1119)
at com.ctre.CTREJNIWrapper.<clinit>(CTREJNIWrapper.ja va:12)
at com.ctre.CANTalon.<init>(CANTalon.java:366)
at org.usfirst.frc.team5243.robot.subsystems.DriveSub system.<init>(DriveSubsystem.java:29)
at org.usfirst.frc.team5243.robot.Robot.robotInit(Rob ot.java:36)
at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:64)
at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:247)
Any help would be greatly appreciated. This error is tearing the team apart, literally.
Unread 06-02-2017, 15:49
Re: CAN Talon SRX Programming
What version of the FRC eclipse plugins are you using?
Unread 06-02-2017, 16:46
FRC #5243
We had updated to the most recent plugins, where we could no longer use the CAN Talon that existed in older versions of wpilib.
Unread 06-02-2017, 16:49
FRC #5243
We have managed to get it working.
We used Filezilla to transfer the .so files(downloaded from http://www.ctr-electronics.com/hro.h...ical_resources) directly onto the roborio (usr/local/FRC/lib)
Unread 06-02-2017, 17:21
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
That would not have been necessary if you followed the README instructions in the zip you downloaded.
OR followed the instructions in section 4.3 in the CTRE Toolsuite Installation Guide.
OR looked up the error in section 3.3 in the CTRE Toolsuite Installation Guide.
