Go to Post Do one thing, and do that one thing very well. - Arille [more]
Unread 01-02-2017, 13:41
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Java Arcade with 3 CIM Gearbox
Following this video...
https://youtu.be/WO-FAKuhpNs?list=PL...d2I4m8Z6gfm7YC
I have 3 CIM gearbox on each side... comment was made that i may need a y to connect 2 motor into 1 PWM port... i guess thats a limitation on the arcade class???
Since we are using Talon SRX with CAN bus, can i assume that i will just each motor separated in my RobotMap.java like this ?
public static final int
Drive_Left1 = 0,
Drive_Left2 = 1,
Drive_Left3 = 2,
Drive_Right1 = 3,
Drive_Right2 = 4,
Drive_Right3 = 5;
Unread 01-02-2017, 13:55
JonKiddy JonKiddy is offline
Programming Mentor (Java/C++)
FRC #4930 (Electric Mayhem)
JonKiddy is an unknown quantity at this point
Re: Java Arcade with 3 CIM Gearbox
Our team also uses a 3 CIM gearbox on both sides for our drive train. Look into a slave/master setup. A CANTalon object can be set to follow another CANTalon object.
http://www.ctr-electronics.com/downl...e%20Manual.pdf
Section 9.1.3
Also, I don't believe a y connector is legal (I could be mistaken).
Unread 01-02-2017, 14:10
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Section 9.1.3
PWM Y connectors are legal, a CAN master/slave setup is also legal. (comma splice, I know)
You need one motor controller for each CIM.
You need 6 motor controllers of the same type and settings.
If you go the PWM route, you will need a total of 4 PWM y connectors.
If you go the CAN route, you can simply daisy-chain all of them together, connecting one to the next, eventually connecting all 6 together in a line.
For CAN, unlike PWM, you need to set up your master/slave setup.
PWM is easier to work with in my opinion.
I hope all these snippets help.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 01-02-2017, 15:07
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
We also have an example that might help....
https://github.com/CrossTheRoadElec/...bot/Robot.java
... basically slave the fifth and sixth talon outside of RobotDrive to the appropriate talons inside RobotDrive.
I argue CANTalon is easier than PWM. If a CANTalon misbehaves you can use the web-based config to determine why - without adding telemetry to your robot code.
A PWM motor controller will provide little feedback as to why it's not doing what you want.
Unread 03-02-2017, 10:33
Coach Seb's Avatar
Rookie Year: 2015
Omar,
do i add these lines in my robot.java class? or to my robotmap.java class?
I am a little confused and very new to java...
I was trying to use Robotbuilder but gave up because the talon SRX are not available... since it feels that it has not been updated since 2013, i am assuming that some new sensors, actuators are missing and feel that i should just code from scratch and learn the hard way... (that's my french sticking....)
I am now trying to follow the WPILIB docs and this video
Wish i could find a resource that explain what the class are for.... These are my assumption... please correct if i am off....
robot.java --> main program, this is what call all other class/methods
robotmap.java --> where i define ports on Roborio, sensors, controller...
OI --> define my joystick and human interface...
I then create subsystem class in which i call the robotmap.java to get the hardware settings ....
Unread 03-02-2017, 10:53
FRC #3007
Rookie Year: 2015
Whether or not you use PWM, before you test the code, remove the motors from the gearbox in case one was wired or programmed in reverse polarity.
Team 3007: 2017
Unread 03-02-2017, 12:29
Coach Seb's Avatar
Rookie Year: 2015
so here is what i did.... Hopefully this make sense...
in my RobotMap.java....
public class RobotMap {
	public static CANTalon _frontLeftMotor = new CANTalon(11);  /* device IDs here (1 of 2) */
	public static CANTalon _rearLeftMotor = new CANTalon(13);
	public static CANTalon _frontRightMotor = new CANTalon(14);
	public static CANTalon _rearRightMotor = new CANTalon(15);
	/* extra talons for six motor drives */
	public static CANTalon _leftSlave = new CANTalon(16);
	public static CANTalon _rightSlave = new CANTalon(17);
then in my DriveTrain_Subsystem class
private RobotDrive MainDrive = new RobotDrive(RobotMap._frontLeftMotor, RobotMap._rearLeftMotor, RobotMap._frontRightMotor, RobotMap._rearRightMotor);
I added the joystick line in my OI.java class
	Joystick _joy = new Joystick(0);
and finally, added the following to my Robot.java class... unfortunately it will not resolved the DriverJoystick .....
	public void teleopPeriodic() {
		Scheduler.getInstance().run();
    	double forward = DriverJoystick.getRawAxis(1); // logitech gampad left X, positive is forward
    	double turn = DriverJoystick.getRawAxis(2); //logitech gampad right X, positive means turn right
    	DriverJoystick.arcadeDrive(forward, turn);
Any help would be appreciated... i think once i resolve how ot properly use the Talon SRX CAN then i can keep going... until then i am kinda stuck...
Unread 03-02-2017, 12:52
Waz Waz is offline
Strategy and programming mentor
AKA: Steve
FRC #2357 (System Meltdown)
Waz is an unknown quantity at this point
You should just use two motor controllers to create your RobotDrive, one for the left and one for the right, and not four. Then set up the other two left side motors as followers of the one left side motor you used to create RobotDrive. Do the same for the right side.
You do not show your code where you actually set up any motors to be followers. It is well documented in the manual that was linked in a prior post.
Edit: I am assuming here that all three motors on one side are on the same gearbox.
Hope this helps,
Steve
Unread 03-02-2017, 12:57
Coach Seb's Avatar
Rookie Year: 2015
do you have an example i could look at?
I though i did... see RobotMap.java up on previous post... i copied directly from Omar github.
Unread 03-02-2017, 12:58
Coach Seb's Avatar
Rookie Year: 2015
yes... using 3 CIM vexpro with Talon SRX...
Unread 06-02-2017, 13:03
Waz Waz is offline
AKA: Steve
See section 9.1 here (http://www.ctr-electronics.com/downl...%20Manual.pdf).
It has the Java code to set up one follower/slave for a master Talon SRX. It is essentially this:
slaveMotor1.changeControlMode(CANTalon.ControlMode.Follower);
slaveMotor1.set(masterMotor.getDeviceID())
You will just need to set it up for two slaves on each side following the same master.
slaveMotor2.changeControlMode(CANTalon.ControlMode.Follower);
slaveMotor2.set(masterMotor.getDeviceID())
Then, just use your two masters (one left and one right) to create your RobotDrive object (it has a constructor that just takes one left and one right motor) and you have it.
I hope this helps,
Steve
Unread 06-02-2017, 17:29
ozrien's Avatar
Omar Zrien
AKA: Omar
Originally Posted by Coach Seb View Post
I was trying to use Robotbuilder but gave up because the talon SRX are not available....
The Talon SRX should be in RobotBuilder. Can you confirm this?
Picture attached.
