Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
  #31   Spotlight this post!
Unread 06-02-2017, 15:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Thunderhex and Thunderhex Bearings
Originally Posted by Jimmy Nichols View Post
Based on our experience last year, this year, and reading others. I think you need to use the Thunderhex bearings, always. You can always throw any hex you have on the lathe and turn it down or sand it down to the 13.75 or 13.73 mm you need.
Even on that front, you will often have trouble getting gears/pulleys to fit over hex purchased from a metal supplier. The tolerances just aren't very good and are often on the + side of 1/2" not minus.
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 06-02-2017, 15:34
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
On that note, do you have any supplies that you would recommend for hex 4140 steel? Haven't come up with a use for it yet, but it may be useful eventually.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
  #33   Spotlight this post!
Unread 06-02-2017, 16:37
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
We have had issues with aluminum hex from local metal suppliers being oversize, but steel hex seems to be usually undersized slightly (as much as standard Vex hex shaft is). I'm not sure if this is luck or just the way the steel is toleranced/manufactured.
  #34   Spotlight this post!
Unread 06-02-2017, 16:43
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Interestingly enough, McMaster's hex rod seems to follow the same trend. The steel 1/2" hex seems toleranced to be slightly under .5", whereas the aluminum rods are around +/- .006.
  #35   Spotlight this post!
Unread 06-02-2017, 17:14
Aren_Hill's Avatar
Build Nifty Things
I've done this before.....Hex Key
Obviously machining it is annoying, but once it's done, you're probably set.
-Aren
A guy who likes robots.
  #36   Spotlight this post!
Unread 06-02-2017, 17:40
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
I bought some 4140/4142 1/2" hex stock from McMaster (#6607k34) two years ago. I just measured out a ~1" long scrap piece at .4915-4925" flat to flat (nominal tolerance is +/- .007") on some cheap digital calipers. As you'd expect, the shaft fits into VEXPro gears easily, but with noticeable backlash.
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
  #37   Spotlight this post!
Unread 06-02-2017, 19:00
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
This thread reminds me of why I preferred round shaft prior to all the major FRC CoTS suppliers switching to hex.
  #38   Spotlight this post!
Unread 07-02-2017, 07:50
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Turns out there was only 1 or 2 shafts that had deformed enough that the Thunderhex bearing would not go on.
Thanks for all the tips and tricks, a couple we knew, but a couple we didn't.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
  #39   Spotlight this post!
Unread 07-02-2017, 08:49
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
-Aren
We did this in 2014 for our catapult cam shaft, with good results.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #40   Spotlight this post!
Unread 07-02-2017, 09:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I guess we got lucky. We bought an 8' length of the 1018 cold rolled hex from onlinemetals.com. It fit our bearings as well as any of our aluminum shafts. The ends were snug (presumably from shipment) but still looser than a press fit. Along the length of the shaft, the bearing slid freely.
