Go to Post You don't have to build a robot to be on a robot team. This isn't about the robot, it's about learning. - engunneer [more]
Unread 02-02-2017, 13:26
thejerishbrown's Avatar
thejerishbrown thejerishbrown is offline
FRC #0190 (Gompei and the Herd)
thejerishbrown is an unknown quantity at this point
Setting PID constants in code for TalonSRX Velocity Control
I'm working with the CTRE Demo code for tuning closed-loop velocity control on the TalonSRX. When I set the PIDF constants in code (using _talon.setP, _talon.setI, etc), the values seem to not get set on the talon itself.
Here's what I'm seeing: When I run the code with any PID constants set, the system doesn't move whatsoever. No matter if I set any combination of P, I, D, or F, there is no response. If I go onto the roborio's web viewer (on http://roborio-<team>-frc.local) I can see the PID constants I set. If I manually re-enter and save the PID constants on the roborio web viewer, the system responds exactly as I would expect.
This only seems to be a problem when I set the control mode to TalonControlMode.Speed. I don't see the problem if I'm using TalonControlMode.Position. I've made sure all the firmware on the TalonSRXs, RoboRIO, and PDP are all up to date, as well as my wpilib and ctre lib installs.
Unread 02-02-2017, 13:42
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Re: Setting PID constants in code for TalonSRX Velocity Control
I just noticed...
 _talon.configPeakOutputVoltage(+12.0f, 0.0f);
... which caps the output to forward only. If you want to spin reverse you should do...
_talon.configPeakOutputVoltage(+12.0f, -12.0f);
... which allows full motor output in both directions.
I think the peak outputs get reset to the defaults when you save in web-config.
Unread 02-02-2017, 13:51
Is this for a flywheel (shooter)?
Unread 02-02-2017, 13:52
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
This is a pretty fly wheel...
#bringingdiscoback
Unread 02-02-2017, 14:01
Originally Posted by ozrien View Post
I just noticed...
This was the problem. Thanks!
Unread 02-02-2017, 16:42
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Depending on your application, you may actually want:
_talon.configPeakOutputVoltage(0.0f, -12.0f);
in the case that you only want it to spin in the 'reverse direction' and never apply 'forward' voltage. If you realize you're driving your car faster than you want on the highway usually you just let off the gas, not throw the engine into reverse.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 02-02-2017, 17:54
ozrien's Avatar
Omar Zrien
AKA: Omar
Capping the output to one direction is perfectly legitimate. However depending on the Fgain, you may not get a direction change caused by being under the target velocity. This happens when the F term provides most of the motor output, and the PID simply tweaks the output to approach the target speed.
This is ideal for applications where you want both directions, such as drive wheels. Here's an example of a team using speed servo all the time on four mecanum wheels...
https://www.chiefdelphi.com/forums/s...+talon+sp eed
Notice our velocity walkthrough in the Talon SRX Software Reference Manual does not require you to enforce only driving in one direction.
Unread 06-02-2017, 21:00
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
This is our first time use of the SRX. We are programming in LabView and using the velocity example program..
We have followed the example for Java velocity closed-loop with interpretations for what LV wants.
I am confused about F-gain. We go through the process. Our motor is running at about 6000 RPM maximum. We get a velocity of 39136 from self-test. Using the formulas we compute F-gain as .026139. If we put that value in the F-gain field in the example, the motor runs to full speed when we set the requested output to -25600 (-3750RPM). Both SRXs are showing Green LEDs.
We have tried bringing down F-gain then setting PID values that get us close to what we want. But with our tuning, the SRX doesn't really regulate. When we start other motors, the speed drops 250 RPM, when we put in a fresh battery, the speed goes up 400 RPM.
I think that we are doing something fundamental wrong. Does F-gain need to change based on the speed we are running.
We are using two motors with one in slave mode. Occasionally the SRXs get out of sync after we download and will buck (one showing RED the other showing GREEN) each other.
Unread 06-02-2017, 23:03
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
I'm assuming you're using a CTRE Magnetic Encoder?
We solved this by deleting the 6.8 multiplier and trying a raw rpm value. Once we did that, the F-gain started to make sense and we were able to tune sensible PID numbers.
See if this helps:
http://imgur.com/a/Ljv4H
Edit: I forgot to add, have you checked to make sure your encoder and your motor controllers have the same polarity?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Last edited by AustinH : 06-02-2017 at 23:05. Reason: Forgot about encoder polarity
Unread 07-02-2017, 03:55
AKA: Randy
Austin, you are a life saver.
Doh, we were showing Green with the encoder counting positive so I thought it was OK. At sometime, the reverse-control-output got set. I don't understand how it did anything but go to full speed in the wrong direction rather than somewhat working.
Thanks again, Hope we see you at World,
Randy
Unread 07-02-2017, 09:24
AustinH's Avatar
Glad to hear it. I would be interested to hear if it took anything else to mod the example code to get your desired function or if I just went a bit crazy with the delete key...
