Go to Post ...from my experience, it is really fun to play defense really well. - Andy Baker [more]
Unread 06-02-2017, 23:55
leiba leiba is offline
FRC #4635
leiba is an unknown quantity at this point
Talon SRX not taking PID values from program
We have a strange thing happening with our Talons SRX.
We have tuned the PIDF using the web config. Once we're happy with the values, we copy them to our program.
Inside our robotinit method, we create the CANTalon objects for each motor, then we:
- set the feedback device (quad encoder)
- set control mode (kspeed)
- set(0) just for safety
- set the config encoder codes per rev (20)
and since we have slave, we set the appropriate.
The problem is this: when our program runs, the talon show a strange behaviour, not running smoothly constantly stopping and starting.
This is fixed by changing any parameter of the PIDF from the web config while running. For example, if P = 0.1, just setting the P = 0.2 from the web config fixes the problem. It continues to work fine even if we set the original value back from the web config.
Any ideas?
Thanks,
Unread 07-02-2017, 01:12
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Talon SRX not taking PID values from program
Grab a self-test before and after and compare the results.
Also if the plugin isn't the latest (as of last Friday) some settings might be getting defaulted when you save a change in the web-based config. That might be why it's behavior changes.
Checkout section 21.27 in Talon SRX Software Reference Manual.
Unread 07-02-2017, 07:07
FRC #4635
Thanks for the response.
We'll compare the self test values before and after.
I can't find a section 21.27 in the current software manual. Is that correct?
Unread 07-02-2017, 12:20
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Yes. Page 151
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 07-02-2017, 12:37
FRC #4635
Sorry, my browser was giving me a cache from the manual.
Thanks,
Unread 08-02-2017, 09:03
FRC #4635
Found my problem.
The Talon were working fine, my problem was that the Allowable Error setting was too high, and so the PID was turning off.
Thanks,
