Our gears mesh perfectly!
Unread 06-02-2017, 18:32
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Sort array in filterContours
Hi
New to Java....
In the Grip generated pipeline code, I want to sort the list of filtered contours to locate the best matches....
Assuming for the moment that I wanted to use area, can anyone show me a code snipit that I can add to the filterContours() method to sort the output array....
Seems like I need to use the Collections.sort() method but I can't get it to accept my arguments.
	 * Filters out contours that do not meet certain criteria.
	 * @param inputContours is the input list of contours
	 * @param output is the the output list of contours
	 * @param minArea is the minimum area of a contour that will be kept
	 * @param minPerimeter is the minimum perimeter of a contour that will be kept
	 * @param minWidth minimum width of a contour
	 * @param maxWidth maximum width
	 * @param minHeight minimum height
	 * @param maxHeight maximimum height
	 * @param Solidity the minimum and maximum solidity of a contour
	 * @param minVertexCount minimum vertex Count of the contours
	 * @param maxVertexCount maximum vertex Count
	 * @param minRatio minimum ratio of width to height
	 * @param maxRatio maximum ratio of width to height
	private void filterContours(List<MatOfPoint> inputContours, double minArea,
		double minPerimeter, double minWidth, double maxWidth, double minHeight, double
		maxHeight, double[] solidity, double maxVertexCount, double minVertexCount, double
		minRatio, double maxRatio, List<MatOfPoint> output) {
		final MatOfInt hull = new MatOfInt();
		output.clear();
		//operation
		for (int i = 0; i < inputContours.size(); i++) {
			final MatOfPoint contour = inputContours.get(i);
			final Rect bb = Imgproc.boundingRect(contour);
			if (bb.width < minWidth || bb.width > maxWidth) continue;
			if (bb.height < minHeight || bb.height > maxHeight) continue;
			final double area = Imgproc.contourArea(contour);
			if (area < minArea) continue;
			if (Imgproc.arcLength(new MatOfPoint2f(contour.toArray()), true) < minPerimeter) continue;
			Imgproc.convexHull(contour, hull);
			// Add new huul
			MatOfPoint mopHull = new MatOfPoint();
			mopHull.create((int) hull.size().height, 1, CvType.CV_32SC2);
			for (int j = 0; j < hull.size().height; j++) {
				int index = (int)hull.get(j, 0)[0];
				double[] point = new double[] { contour.get(index, 0)[0], contour.get(index, 0)[1]};
				mopHull.put(j, 0, point);
			final double solid = 100 * area / Imgproc.contourArea(mopHull);
			if (solid < solidity[0] || solid > solidity[1]) continue;
			if (contour.rows() < minVertexCount || contour.rows() > maxVertexCount)	continue;
			final double ratio = bb.width / (double)bb.height;
			if (ratio < minRatio || ratio > maxRatio) continue;
			// Add to main output list
			output.add(contour);
Phil Malone
http://www.GEARSinc.org
Unread 07-02-2017, 06:58
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Sort array in filterContours
When sorting objects with the Collections.sort() method, you will typically want to supply the "comparator" parameter that lets you control the comparison between each object (decide which should come before the other).
For example, if you want to sort by area, I think you can use a static helper method something like the following:
  public static void sortContoursByArea(List<MatOfPoint> contours) {
    Collections.sort(contours, new Comparator<MatOfPoint>() {
      @Override
      public int compare(MatOfPoint a, MatOfPoint b) {
        // Not sure how expensive this will be computationally as the
        // area is computed for each comparison
        double areaA = Imgproc.contourArea(a);
        double areaB = Imgproc.contourArea(b);
        // Change sign depending on whether your want sorted small to big
        // or big to small
        if (areaA < areaB) {
          return -1;
        } else if (areaA > areaB) {
          return 1;
        return 0;
Hope that helps
Unread 07-02-2017, 10:03
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
FWIW you could also write that as
  Collections.sort(contours, Comparator.comparingDouble(Imgproc::contourArea));
WPILib
GRIP, RobotBuilder
Unread 07-02-2017, 12:05
PhilBot's Avatar
AKA: Phil Malone
Hope that helps
Terrific. We were heading in that direction but couldn't get the eclipse to accept our code.
We were just trying to call the Collections.sort in-line.
Your static method went in with no problems.
I'll have to investigate further to understand why the static method worked, but the inline code didn't.
Thanks again for the detailed response.
Phil Malone
Unread 07-02-2017, 12:13
PhilBot's Avatar
AKA: Phil Malone
That's a really interesting syntax.
Is there a name for what is hapening with "Imgproc::contourArea" ?
I'd like to look up the explanation of how that works...
Clearly it's getting expanded internally into Imgprog.contourArea(contours[n]) for the comparison.... but I don't know how/why.....
Phil Malone
Unread 07-02-2017, 13:12
FRC #2084
That's called a method reference.
This article explains it quite well
Also, you don't even need a special method for sorting a list. The List interface defines a method "sort(Comparator)" that you can use inline like
contours.sort(Comparator.comparingDouble(Imgproc::contourArea));
WPILib
GRIP, RobotBuilder
Unread 07-02-2017, 14:01
PhilBot's Avatar
AKA: Phil Malone
Dang... As an "vintage" programmer, it's sometimes scary when I realize how much I don't know about the "newer" languages. That's pretty darn powerful.
Phil Malone
