Go to Post PLIERS: Used to round off bolt heads. - Andy A. [more]
Unread 07-02-2017, 11:31
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: "Velcro" Ropes
Any suggestions here would be guesses, as it is up to the inspector and LRI at your event to determine, and the Q&A will not take this question far enough to give a positive answer.
As a simple alternative, many ropes have the fibers loose enough that Velcro hooks on the drum will snag them just fine.
