My love spiders out in a web of emotions when I think of you.
Unread 07-02-2017, 12:05
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Sort array in filterContours
Originally Posted by pblankenbaker View Post
When sorting objects with the Collections.sort() method, you will typically want to supply the "comparator" parameter that lets you control the comparison between each object (decide which should come before the other).
For example, if you want to sort by area, I think you can use a static helper method something like the following:
Hope that helps
Terrific. We were heading in that direction but couldn't get the eclipse to accept our code.
We were just trying to call the Collections.sort in-line.
Your static method went in with no problems.
I'll have to investigate further to understand why the static method worked, but the inline code didn't.
Thanks again for the detailed response.
Phil Malone
http://www.GEARSinc.org
