Go to Post still emotion conveyed through text is really strange. - Blackphantom91 [more]
Unread 07-02-2017, 12:59
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
pic: Inventor Practice Update
Unread 07-02-2017, 13:08
Big-b's Avatar
Big-b Big-b is offline
FRC #0900 (♞Zebrarcorns♞)
Team Role: CAD
Rookie Year: 2016
Big-b has a spectacular aura aboutBig-b has a spectacular aura about
Re: pic: Inventor Practice Update
How are you getting the fuel into the shooter? From looking at the model, it seems like they would have to come from outside the bot.
Unread 07-02-2017, 13:12
The fuel gets pulled from the bottom of the hopper and into the shooter. I haven't added that bit yet, but it goes where the bearings under all those spacers that form the arc are.
It isn't shiny enough.
Unread 07-02-2017, 13:15
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Just curious, is your wheel well 6" wide in the front to accommodate the 6" minimum bumper length from the corner rule?
461 Westside Boiler Invasion
45 Technokats
Unread 07-02-2017, 13:17
Big-b's Avatar
Team Role: CAD
Rookie Year: 2016
I see it now, thanks. The model looks really good, are you thinking of posting the cad when you're done?
Unread 07-02-2017, 13:24
The bumpers themselves will be 6" wide in the corners. Is this illegal?
Unread 07-02-2017, 13:25
Thanks! I might consider it
Unread 07-02-2017, 13:35
Nessie Nessie is offline
FRC #2702 (Rebels)
Nessie is an unknown quantity at this point
They have to be adequately supported. Read the bumper rules very carefully. I am not involved in our team's cad design, but I know that our team has started to cad the frame with bumpers right from the start and found it super helpful. Less issues later on. (We had years in the past where bumpers were the last thing and finding places to put the brackets was close to impossible. Then once they were placed, replacing bumpers was difficult.)
Edit: Bumper constraints = frame constraints.
Last edited by Nessie : 07-02-2017 at 13:37. Reason: Added a simplified way of communicating my idea.
Unread 07-02-2017, 13:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
No, it's required. However, be mindful of R31, particularly the part I made bold:
Originally Posted by R31
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 8-7). To be considered supported, a minimum of ½ in. (~13 mm) at each end of the BUMPER must be backed by the FRAME PERMIETER. Additionally, any gap between the backing material and the frame:
  • A. must not be greater than ¼ in. (~6 mm) deep, or
  • B. not more than 8 in. (~20 cm) wide
Some angle brackets on the side of the wheel modules that extend in to 6" from the corners would be adequate to comply with the rules.
Unread 07-02-2017, 13:44
Thanks! I seemed to have neglected reading that bit...
