Go to Post I clicked on "agree to terms" ........ crash. I think I killed the server. ;) - rees2001 [more]
Unread 07-02-2017, 14:24
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Horizontal FOV of Microsoft Lifecam Cinema
Title. I can't seem to find this information in the interwebs.
EDIT: Sorry for the confusion, this is NOT the HD-3000. This is a different product.
https://www.microsoft.com/accessorie...nema/h5d-00013
Unread 07-02-2017, 14:35
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: Horizontal FOV of Microsoft Lifecam Cinema
The Microsoft webpage has a link to the datasheet for this product.
https://www.microsoft.com/accessorie...hspecs-connect
From the datasheet, the diagonal field of view is listed as 68.5 degrees.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 07-02-2017, 14:57
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Here's an old thread that has some numbers:
https://www.chiefdelphi.com/forums/s...d.php?t=144285
Empirically, my team has found that 53* is closer to correct.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 07-02-2017, 15:00
TigerVision TigerVision is offline
FRC #3654
Rookie Year: 2016
TigerVision is an unknown quantity at this point
Interesting! Empirically, we found HFOV is about 53 degree too.
Unread 07-02-2017, 15:06
FRC #3331
That is the wrong webcam. This is the right one: https://www.microsoft.com/accessorie...nema/h5d-00013
Unread 07-02-2017, 15:07
FRC #3331
Unread 07-02-2017, 15:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That's mostly the difference between horizontal FOV and diagonal FOV. Using 53.0 degrees HFOV and a 16:9 ratio between the HFOV and VFOV and the formula for the angle between two points on a sphere given latitude and longitude, and assuming that rectangle is bisected by the equator, I get 66.0 degrees as the diagonal FOV.
Unread 07-02-2017, 15:24
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
According to the datasheet (copied directly off the page you linked to), the diagonal is 73 degrees.
Edit: from 16:9 ratio, inferred HFOV is 64.4 degrees, VFOW 36.2 degrees.
Unread 07-02-2017, 15:32
FRC #3331
Thanks. I wasn't sure how to do the calculation for diagonal to horizontal.
