Go to Post Looks like we will be building a wood robot :) - IndySam [more]
Unread 06-02-2017, 21:34
WalnutsAndBolts WalnutsAndBolts is offline
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Exclamation Please Help With Pneumatic Programming
Hi,
I have been working for the last 3 days to program the solenoids on my teams robot. I have asked a few different times how to do this, but nothing seems to work. Would anyone be willing to share images of there Labview solenoid/pneumatic code? It would also be helpful if someone could help us work out this bump in the road, if we still get stuck.
Thank you all so far, and please help me get through my rookie year with my sanity ,
Walnuts and Bolts Robotics Team
Unread 06-02-2017, 21:46
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Re: Please Help With Pneumatic Programming
The snippet attached should show the basics of using solenoids. If you have a single solenoid, you want to use the "On" and "Off" values of the enum constant, and if you have a double, use "Forward" and "Reverse".
The example will turn on a single solenoid on the press of button 0 (and turn it off when released). Button 1 controls the forward/reverse state of the double solenoid. If you want to toggle, then read through this thread.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 07-02-2017, 14:38
Hess1113's Avatar
Hess1113 Hess1113 is offline
Grab a computer and code it up!
AKA: Christopher Hess
FRC #0291 (Creativity In Action)
Rookie Year: 2017
Hess1113 is an unknown quantity at this point
Use the solenoids to open in the begin.VI like how you would a motor
Then Hitchhiker had a good example as above but for the global variables you could use True or False, One and Zero, Or On and Off. If you have any questions just DM
Christopher Hess
Co-Lead Programmer
Webmaster
FRC-Team 291 CIA
www.team291.com
Unread 07-02-2017, 14:52
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Rookie Year: 2015
Robomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to beholdRobomarfa is a splendid one to behold
Make sure you have programmed the CAN address of the pneumatics module to be unique. Use the RoboRio web viewer to see/change CAN addresses.
