Go to Post I understand that I'm in the minority when it comes to these things, so when the coverage switches to one these stories I exercise my right to change the channel. - Karthik [more]
Unread 07-02-2017, 17:05
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
LED Strip Issues
We're trying to put LED strips on our robot to signal various things to the drivers, as well as improve the look of our robot. We're using this strip
https://www.adafruit.com/products/2440, with these MOSFETs on the signal wires:
https://www.adafruit.com/product/355
We're trying to power it off of the roboRIO PWM outputs, but we're getting a weird issue where the LEDs are rapidly flashing at a lower-than-full brightness. My thought when this originally happened was that it was because our power ground wasn't connected to the signal ground (we're powering them directly from the VRM, while signal is from the roboRIO PWM pins), so we fixed that but they still don't work.
Unread 07-02-2017, 17:21
Smalls1625's Avatar
Smalls1625 Smalls1625 is offline
AKA: Zane
FRC #1625 (Winnovation)
Rookie Year: 2016
Smalls1625 is an unknown quantity at this point
Re: LED Strip Issues
How we did it last year was off the PCM,I believe. You can then program each of the colors as a solenoid.
Unread 07-02-2017, 18:31
Rookie Year: 2016
Yeah, we could run it off of the DIO pins, but we'd like to have more colors available than that.
