Go to Post WHY WON'T THESE THREADS DIE!!!!!!! Eeach and every year there are at least two discussions about water games. - Rickertsen2 [more]
Unread 07-02-2017, 19:21
Southpaw's Avatar
Southpaw Southpaw is offline
AKA: Spencer Robinson
FRC #3184 (Blaze Robotics)
Southpaw is on a distinguished road
Rails vs Plates
Our team is currently in the discussion of a dual railed shooter versus a single backing plate. We have prototyped both, but I was looking for input from other teams and what they may have found.
Unread 07-02-2017, 19:31
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant future
Re: Rails vs Plates
Could you describe the setups in greater detail? What do you mean by "dual rail" and in what orientation? Drawings, even MS Paint ones, would help immensely here.
Unread 07-02-2017, 19:34
Southpaw's Avatar
Re: Rails vs Plates
Of course sorry about that. The dual railed system is like this
https://www.youtube.com/watch?v=ty9qpTeYAWA
The other design would be a simple flat plate along the back. Both are curved.
Unread 07-02-2017, 19:39
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Rails vs Plates
This is a decision your team has to make for yourselves. Both carry inherent advantages and disadvantages, but the real difference comes in how each one fit into your design. Dual rails offer the ability to vary the compression by changing the lateral distance between rails. A flat plate offers the advantage of being a consistent backing even if the ball doesn't follow the exact same path every time.
What shooter wheels are you using, and in what setup? If you're using two shooter wheels with a gap in between, I'd probably avoid the dual rails. While in a perfect world this would be fine, the system would be very sensitive to inconsistent loading. But ti all depends on the rest of your system and what you can produce.
Unread 07-02-2017, 20:50
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: Rails vs Plates
This. We've done both styles (even within a single year), and though I'm sure it can be done well, in my experience it can be a mess in terms of accuracy. The key is that you don't really care if the balls come out in exactly the same position. The +/-x mm of variation there won't really matter. What you do need is balls that come out at exactly the same angle. Over the distance that they'll travel, small differences in angle (especially horizontal) will add up, and that's what makes all the difference. It can have its downsides depending on your design, but flat backing and wide wheel will take a ball and send it straight forward every time.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
