Go to Post May your shirts be full of buttons, yours inspiration be plentiful, and your error messages be few. - Barry Bonzack [more]
Unread 07-02-2017, 14:39
5854RoboProgram 5854RoboProgram is offline
AKA: Keegan
FRC #5854 (Glitch)
Rookie Year: 2016
5854RoboProgram is an unknown quantity at this point
More Than Two USB Cameras??
Hello FRC programming community,
I am the lead programmer on team 5854, this is the team's second year and my first as lead programmer.
I am using usb cameras to get images to my vision system. I have two cameras hooked up to the usb slots on the roborio and I am using a custom class I made using the built in CameraServer library. (Code Example below) I was wondering if there is a way to make a third camera streaming service. Or if there would be a problem using a usb splitter because I'm not sure how the rio will handle it.
Thnak you in advance.
And sorry if the text is confusing or misspelled, I'm dyslexic.
Code on how I'm making the camera server:
usbCamera = new UsbCamera("USB Camera 0", cameraId);
usbCamera.setResolution(640, 400);
usbCamera.setBrightness(1);
mjpegServer1 = new MjpegServer("serve_USB Camera 0", 1181);
mjpegServer1.setSource(usbCamera);
cvSink = new CvSink("opencv_USB Camera 0");
cvSink.setSource(usbCamera);
outputStream = new CvSource("Blur", PixelFormat.kMJPEG, 640, 480, 30);
mjpegServer2 = new MjpegServer("serve_Blur", 1182);
mjpegServer2.setSource(outputStream);
Unread 07-02-2017, 15:36
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: More Than Two USB Cameras??
Using more than two cameras is certainly possibly. Don't use a "USB Splitter", instead just simply use a USB hub on the robot. It may get a little funky with too many because of current draw. Once plugged in, they should simply show up on the roboRIO dashboard, and you should be able to create another CameraServer class.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 07-02-2017, 19:58
We've used 3 HD-3000's. You have to be careful with the resolution and fps, because you can run into USB bandwidth issues.
Unread 07-02-2017, 21:33
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
thecoopster20 is an unknown quantity at this point
I highly recommend using something along these lines to make sure that you are only ever streaming the camera you want, instead of wasting bandwidth by streaming multiple cameras at the same time.
public void robotInit() {
    	Thread t = new Thread(() -> {
    		boolean allowCam1 = false;
    		UsbCamera camera1 = CameraServer.getInstance().startAutomaticCapture(0);
            camera1.setResolution(320, 240);
            camera1.setFPS(30);
            UsbCamera camera2 = CameraServer.getInstance().startAutomaticCapture(1);
            camera2.setResolution(320, 240);
            camera2.setFPS(30);
            CvSink cvSink1 = CameraServer.getInstance().getVideo(camera1);
            CvSink cvSink2 = CameraServer.getInstance().getVideo(camera2);
            CvSource outputStream = CameraServer.getInstance().putVideo("Switcher", 320, 240);
            Mat image = new Mat();
            while(!Thread.interrupted()) {
            	if(oi.getGamepad().getRawButton(9)) {
            		allowCam1 = !allowCam1;
                if(allowCam1){
                  cvSink2.setEnabled(false);
                  cvSink1.setEnabled(true);
                  cvSink1.grabFrame(image);
                } else{
                  cvSink1.setEnabled(false);
                  cvSink2.setEnabled(true);
                  cvSink2.grabFrame(image);
                outputStream.putFrame(image);
        t.start();
Unread 08-02-2017, 08:15
ajsmith's Avatar
ajsmith ajsmith is offline
Captain, Programming, Build
AKA: Andy Smith
FRC #5546 (A.R.T.)
ajsmith is a jewel in the roughajsmith is a jewel in the roughajsmith is a jewel in the rough
            camera1.setFPS(30);
            camera2.setFPS(30);
                if(allowCam1){
                } else{
        t.start();
I've seen this code in multiple threads here but I have never been able to get it to work. We always end up with the "too many simultaneous client streams" error whenever we try to switch to the second camera (setting allowcam1 to true). Any ideas on why this isn't working for us?
EDIT: We just tried a new robot program with just this code and got it to work. If anyone else has this error, we had to change the source in smartdashboard to "switcher," then RESTART the smartdashboard and the robot, and then it would work. I think the problem was that since the smartdashboard had started off streaming the usb cam 0, it never stopped streaming after switching sources.
Unread 09-02-2017, 20:44
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
What do you mean when you say you have to change the source to "switcher?"
Unread 09-02-2017, 21:40
ajsmith's Avatar
AKA: Andy Smith
FRC #5546 (A.R.T.)
In SmartDashboard, the USB Camera Viewer widget has a source property. In the code above, it says "putVideo("Switcher", 320, 240);" so that is the new video source. The Java code automatically adds a "Camera 0" or "cam0" source for the webcam, but using that produces an error when switching cameras because you are still trying to stream that single camera rather than the special source that will switch between the two.
