Go to Post CAD is the oxygen for engineering. - Bharat Nain [more]
Unread 07-02-2017, 21:24
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
PID I value tuning issues
Hey y'all,
So we've been tuning an auto-alignment feature for aligning with the goal (using vision). We're successfully filtering the image, and calculating the image and distance. In tele-op, we're using the built-in LabVIEW PID loop (see attached image). When we are tuning the PID constants, though, the I constant seems to have no effect. Our robot gets close to the needed angle, but even an extremely large (10^4) value for I seems to not change the robot's motion at all. Advice? We're relatively new to using PID control.
Set-up:
NavX
6WD Tank
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 07-02-2017, 23:12
Eryl2000's Avatar
Eryl2000 Eryl2000 is offline
FRC #3024 ("My Favorite Team")
Eryl2000 is on a distinguished road
Re: PID I value tuning issues
What PID gains are you using?
Also, it is important to note that the way LabView sets up their PID is different than you might expect. Changing the Kp gain actually effects Ki and Kd gains. This is because LabVIEW uses Kp, Ti, and Td, which is because of the different control setup they use.
Also, I believe that Ti is inversely proportional to Ki, so try decreasing it? I might be wrong, but I am pretty sure that is how it works.
Unread 07-02-2017, 23:19
Roboter
Rookie Year: 2015
We got to a Kp = 0.025 which would make the robot oscillate around the target. Didn't tune the other values. I'll try what you suggested.
Unread 07-02-2017, 23:22
Eryl2000's Avatar
If you got the robot to oscillate you might consider increasing Kd. The derivative term is supposed to control damping.
Unread 07-02-2017, 23:25
Roboter
Rookie Year: 2015
Is Kd straightforward in LabVIEW, or does it depend on Kp and such as well?
Unread 08-02-2017, 01:41
Eryl2000's Avatar
Unfortunately, Kd is also dependent the proportional gain. LabVIEW uses Kp, Ti, and Td.
However, this does not mean you need to throw PID rules of thumb out the window. Generally, I find an oscillating Kp like you did, add Td until I achieve a step response that fully dampens after 1-2 small overshoots (or less depending on the application), and then add in Ti if necessary to reduce steady-state error.
Hope this helps
Unread 08-02-2017, 08:57
blturner blturner is offline
FRC #5013 (Trobots)
blturner is on a distinguished road
I believe that Labview has Integral windup prevention. When the I gets above a certain value it sets it back to zero.
So if you set it super high it will think it is winding up and set it to zero all the time.
Integral would typically be rather small values. I don't have enough experience to tell you what range to expect. In my previous applications it would be from .0001 to .25
