Go to Post Greetings FIRST: THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU. - Tetraman [more]
Unread 07-02-2017, 21:30
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
H-Drive Strafing issues
Hey CD
So we are experiencing traction trouble with our H-Drive chassis. When we attempt to strafe, sometimes the wheel just turns and doesn't catch on the ground. We were doing it on polished cement, so that may be an issue, but what to do you all think, what should we do?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 07-02-2017, 21:35
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Re: H-Drive Strafing issues
When we did this in 2015, we found that on carpet, the robot sinks significantly into the carpet for the wheel to catch. You should probably try this out on carpet and see if this is the case. If it is, great! If it still doesn't catch, you may need to lower your center wheel.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 07-02-2017, 21:38
Southpaw's Avatar
Southpaw Southpaw is offline
AKA: Spencer Robinson
FRC #3184 (Blaze Robotics)
Southpaw is on a distinguished road
Carpet will most certainly help, what wheel is your strafing drive?
Unread 07-02-2017, 21:40
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Is the strafing wheel at a set position? Is there any way you can increase the amount of normal force on that middle wheel? Carpet will almost certainly help. But it probably won't fix the problem.
Unread 07-02-2017, 22:58
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
The center wheel has no applied force on it, but we do have the majority of our heavy weight items (battery, etc.) toward the center wheel. It is just an Omni wheel with rollers. We should be taking it up to the practice field soon
Unread 08-02-2017, 06:31
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
In 2015 our strafe wheel was in a spring powered suspension setup to keep it in contact with the ground. I don't know what your setup looks like, but it's very difficult to keep weight on a fixed center wheel without lifting up other wheels. One of the best methods I've seen is what 148 did in 2014 with their "rocker" module. Perhaps someone from their team can elaborate on it further.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 08-02-2017, 08:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We tried strafe with H-drive in 2015, using a hard chassis mount. No matter how high or low we put it, it never worked right. Off season, we used a pneumatic cylinder to apply a steady force to it, and it worked first try. Springs can also work, I understand. The force on that wheel should be roughly between 20% and 35% of the weight of your robot, depending on how much strafe force you want and how much forward drive force you're willing to give up while you strafe.
Unread 08-02-2017, 09:59
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Think it would work if we just ran it on the carpet? We are using a Vex versaframe H drive chassis
Unread 08-02-2017, 10:04
Chris is me's Avatar
AKA: Pinecone
Is the center wheel rigidly mounted to the frame, or is it articulated? An articulated strafe wheel will do a much better job contacting the ground. One COTS way to do this with VersaFrame would be to use a drop drive module with only one wheel in it (I've never tried this, it just seems like it would work).
If your frame uses VersaBlocks, be sure you don't accidentally have the drop center in the wrong direction.
A picture would really help here.
Unread 08-02-2017, 10:44
pmattin5459 pmattin5459 is online now
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
He said that with a hard mount, no. You need some sort of actuation. I would suggest the RoboWrangler way from the comment above if you don't want to use pneumatics.
Unread 08-02-2017, 11:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Correct. It didn't matter whether we ran on bare floor or carpeting; we never got a useful strafe with fixed mounting, even when we tried a slot and use cable tension to hold the gearbox/wheel down.
Unread 08-02-2017, 11:20
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
So you suggest Vex Versadrop?
Unread 08-02-2017, 11:50
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
When we did our H-drive in 2011 (which worked very well), our center wheel was on a simple suspension system. We put the center wheel on a swing arm and used a gas strut from McMaster Carr to provide the spring and damping. The trick was to size the gas strut to provide 1/5 of the robot's weight to the center wheel.
Unread 08-02-2017, 11:58
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
That would be one way, and the only COTS design that comes to mind. Our off season version was home brew, and not at all optimized, more a proof of concept. In some way, you need to have the wheel able to move up and down, and apply a relatively steady force to hold it down as it moves. Pneumatics gives you the option of lifting the strafe wheel up (or at least not pushing it down) to maximize traction on your primary drive wheels.
Unread 08-02-2017, 11:59
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
If you don't have space for a gas shock constant force springs work well too.
2012-Present Wave Robotics Team 2826
