Go to Post We didn't need a championship to recognize the kids on our [little league] team and we sure didn't need one to inspire them. If you want to go to the championships then work harder, don't try and lessen the value of the championships by letting everyone in. - FarmerJohn [more]
Unread 09-01-2017, 09:37
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
kprzewodek is on a distinguished road
2017 Bosch Seat Motor
Just want to open up a thread for general questions about the Bosch seat motor in all Kits this year 6 004 RA3 194-06.
Firstly I’ll just go ahead and disclose that I work for Bosch and that my opinions represent my own and do not reflect official statements from Bosch.
This motor is good as a general purpose motor if you want a ready to go solution. I know the star output isn’t so FIRST friendly but there are some solutions to make the job easier by either broaching a 3/8” hex, adapting to a general socket, 3D printing an adapter or cutting down hex shaft into a square that fits the profile. Some tips are available in a screen steps presentation (linked below). Once you solve that problem most teams even those with few resources can make it work.
It compares with the window and snow blower motor however has more torque at lower speed. There's also a built in hall sensor and a thermal protector if you over work the motor. Since it's a worm driven gear system it resists backdrive very well.
Here’s a few general links to find more information:
- Thread from last year (now closed)
https://www.chiefdelphi.com/forums/s...sch+seat+motor
- Screen Steps document with some general tips, spec sheet and CAD model
http://wpilib.screenstepslive.com/s/...sch-seat-motor
This motor is available through FIRSTchoice second round if you need backups and should be available through AndyMark a bit later in the season.
Unread 02-02-2017, 09:37
kprzewodek's Avatar
Re: 2017 Bosch Seat Motor
Just FYI if backups are needed this is now for sale at AndyMark. You can get harnesses alone or packaged with the motor.
http://www.andymark.com/product-p/am-3493.htm
Last I checked there was still some FIRST choice stock.
Unread 02-02-2017, 09:44
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Confirmed, they're 20 points
#StaySavage
Unread 02-02-2017, 09:57
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
From your suggestions, my team had actually tried to mill down a 1/2" hex shaft to a square to fit. We had a nice interference fit, but the issue really is the amount of material you end up removing. The result is a very small shaft that, in our case, ended up sheering under load (the motor never stalled, we got about 10 turns before it broke). So, the lesson there is don't use aluminum shaft if you go that route!
2016: Lake Superior WFFA
Unread 02-02-2017, 10:06
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
My team has had good results, both last year and this year, using 3/8" hex shaft after drilling out the plastic spline and broaching. However, none of our applications have required the full torque capability listed on this motor's data sheet. We have used it to adjust tilt angle for various mechanisms that do not have a lot of overhanging load.
After broaching 3/8" hex, the plastic coupling is fairly thin. Has anyone used this method and loaded it heavily; e.g., torque > 100 in-lb?
Richard Wallace
since 2003
Unread 02-02-2017, 10:09
kprzewodek's Avatar
Thanks for the feedback. I'll see if we can update the sheet to make sure other teams learn from your experience.
Unread 02-02-2017, 10:13
kprzewodek's Avatar
We've also had a good experience broaching 3/8". Not sure if it reached full loading but it was pretty close.
I also tried adding a 1/2" socket bit and filled the gaps with epoxy. Haven't torture loaded but it was holding up for some mid load prototyping.
Just remembered we did some torture testing. Information is in last years thread about half way through. https://www.chiefdelphi.com/forums/s...sch+seat+motor. I should point out that this was using a rotary broach which doesn't quite give you the flat sides that a linear broach provides.
Unread 02-02-2017, 23:42
Mentor, LRI, MN RPC
Update for this...
We swapped out our prior solution tonight for the ˝” socket bit option in the screen steps live link. it worked perfectly for our application. We don't really need the max torque the motor can put out, but rather the form factor and speed are what makes it a good fit for this particular application. Being able to get this working tonight after having our milled square solution break on Tuesday was really great - it's nice not having to wait for additional parts (if we were to go with the 3/8" hex option, as we don't have any of that in stock, only 1/2") or switch to a different solution. Having these options presented like this really made it easy to understand and made my student's evening!
Unread 03-02-2017, 08:40
kprzewodek's Avatar
Update for this...
That's awesome! I'm so glad it worked out. Keep us posted if it holds up. I think we all know that feeling all too well when something fails and we must scramble for a solution. I think next year we should have an adapter available.
Unread 08-02-2017, 02:47
brainbounce brainbounce is offline
AKA: Bob
FRC #3225 (Wolverine Robotics)
Rookie Year: 2016
brainbounce is an unknown quantity at this point
We are using it for a lifting mechanism. I found some 6mm square steel stock, and some 5/16" steel spacers at our local industrial hardware supply. The square is a super tight fit, is easy to weld onto any attachment, and spins nicely in the spacers welded to a bracket. Overall, this was probably the easiest custom motor to mount so far. Having the right parts is the key.
Unread 08-02-2017, 09:05
kprzewodek's Avatar
Thanks for sharing! Plastic does creep over time with heavy loads so I would suggest possibly filling the gap with JB weld or some other high strength epoxy if you find slop start to develop. Doubling up on the motors will help distribute the load a bit too.
Unread 08-02-2017, 10:50
FRC6055 FRC6055 is offline
MUSE
AKA: Austin Muse
FRC #6055 (The Pioneers)
Rookie Year: 2016
FRC6055 is an unknown quantity at this point
We decided to use it to lower our gear holder to place it on the peg. We machined down a hex shaft to a square to fit tightly into the star output. It fits very tightly and we are very happy with how easily it lowers and lifts the gear holder with the gear in it. The encoder enable us to lower the holder to a specific degree to drop the gear on the peg or lean forward to receive the gear then come back to vertical. The only issue we are having is we are noticing that our encoder is losing counts and after repeated cycles of rotating up and down, it will not rotate down as far or rotate up as far.
2016 Arkansas Rock City Regional Winner & Rookie All-Stars
"Mr. Muse, where is the 8/13" wrench?"
Unread 08-02-2017, 11:45
kprzewodek's Avatar
In the automotive application for this motor there's actually a 12V input to the hall so the peak to valley of the wave is more than you get with a 5V signal. I wonder if that could be the reason you might loose some counts. Can you keep track of your counts and compare with actual? Should be ~175 counts per output revolution. Maybe put a limit switch to zero and reset your reference so count losses don't add up over time. Since I don't have much experience on the programming side I would be interested if this is a big problem for other teams and if they found a good solution.
Unread 08-02-2017, 12:16
chesterm chesterm is offline
AKA: Chester Marshall
FRC #6055 (6055 and 5721)
Rookie Year: 2016
chesterm is an unknown quantity at this point
We have noticed the loss of counts also. In our case it appears to do well when speed is at 50% or less. Going above that led to increasing loss of counts. We are planning on a home switch to re-zero counts every time our tilt returns to the up position. Haven't tested it yet, but I expect it to work out ok.
Unread 09-02-2017, 11:28
MUSE
AKA: Austin Muse
Rookie Year: 2016
Yes. We plan to put a limit switch at the top of its motion to make sure it resets back to zero every time it comes back up.
