Go to Post The stated goals of FIRST are to inspire a culture that values science and technology. Inspiration needs Motivation. What motivates people? Competition. - Dmentor [more]
Unread 08-02-2017, 16:00
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Running GRIP Generated Code on Roborio
GRIP's new code generation feature and WPI's new vision-related features are very useful. However, having used GRIP on the driver station with about a quarter second of latency, is the latency better/worse if you run the code on the roborio?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 08-02-2017, 20:58
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Running GRIP Generated Code on Roborio
Depends on image size, driver station computing speed, and a little bit of luck.
For reference, the GRIP pipeline bundled with this years vision examples generates a Java class that processes a 640x480 image in about 80ms. I can run the same GRIP file in about 12ms on my laptop with an i7 6700HQ with an overall latency probably around 150ms on average.
WPILib
GRIP, RobotBuilder
Unread 09-02-2017, 00:02
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
So what you're saying in the above examples is that, all things included, running on roborio produces 80ms latency vs. 150ms on the powerful laptop?
My FRC History:
Unread 09-02-2017, 00:10
FRC #2084
In general. I should note that running vision code on the roborio is resource intensive since it's basically pegging a CPU core, which basically precludes you from running another resource-intensive thread.
The latency estimate I gave was very pessimistic (assumed 100ms response time for NetworkTables and a slow image stream). Again, the actual processing only takes about 12ms for me, with all other latencies being due to the network.
The best solution would be to use a coprocessor for doing vision, if you can.
WPILib
GRIP, RobotBuilder
Unread 09-02-2017, 01:39
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Alright, sounds good! Thanks so much for the help!
My FRC History:
Unread Yesterday, 09:06
You may also want to consider running the camera at a lower resolution or limiting where you do the processing. 320x240 is 1/4 as many pixels, and if that is good enough to identify the elements in your image, ...
Greg McKaskle
Unread Yesterday, 09:29
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Thanks for the help everyone! I was able to get this working last night, but there is still one issue mentioned in this thread. If you have encountered this or know how to solve it, check it out.
My FRC History:
