Go to Post People can talk a big game, but unless they start working on what they talk about, nothing will get done. - Lisa Perez [more]
Unread 08-02-2017, 17:32
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: Recommended gyros that can keep up with fast rotation?
Originally Posted by Tom Line View Post
I'm curious what data and performance testing you've done on competitive products to make that statement. There are a number of IMU's on the market other than that navX. Have you tested them?
I am in no way disparaging the NavX. We've played with it and it works very well. However, I'm an engineer and I try not to make statements that product A is better than product B unless I have seen a marked difference in some measurable.
Well, I'm biased a bit, but wanted to share my thoughts:
Pigeon specs are similar to navX-MXP/navX-Micro for 6-axis performance from a yaw drift rate, make sense as they use the same chipset which performs the 6-axis fusion onboard. The navX-MXP/navX-Micro firmware for calibration has improved over the two years, but it's likely safe to assume the Pigeon orientation angle accuracy after calibration is similar (sounds like it, according to published specs).
Pigeon update rate is 100hz, navX-MXP/navX-Micro are 200hz, so if you want faster update rate the latter is superior. 200Hz is great if you want to drive rapid PID loops that manage the orientation of multiple wheels on the robot.
We will have to see if there's any CAN bus contention limits the Pigeon IMU from consistently achieving update rate at 100hz, CTRE should be able to say on that. At 1mbps w/the PDP, 4 talons and a PCM all chatting on the CAN bus, and 100hz Pigeon updates there may be some contention starting to arise - that remains to be seen. However, in the configuration to connect directly a Pigeon to a Talon this would likely not be a concern.
From a software perspective, the Pigeon docs indicate it provides yaw, pitch and roll - however the navX-MXP/navX-Micro also (perhaps because it's not limited to the 8-byte CAN bus data payload sizes) provide synchronized quaternions and a sensor timestamp as well. Timestamped Quaternions (and the fact that navX-MXP/navX-Micro have multiple simultaneous communcation interfaces) are being used effectively in the Sensor Fusion Framework (SF2) to correct for video processing latency, and create timestamped orientation histories. As a contributor to SF2, I can say that more features along this line are coming. Software is key to enabling more autonomous features.
For newer teams the number of examples, the training materials and the large community that support navX-MXP/navX-Micro and help each other too are awesome.
So in addition to orientation accuracy specs which I believe are very similar, there are several system and software level capabilities to also consider.
