Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 08-02-2017, 18:38
verlander13 verlander13 is offline
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
verlander13 is an unknown quantity at this point
Exclamation Detecting countours
Can anyone explain why my code will not stop once centerX1 is equal to 237?
package org.usfirst.frc.team1025.robot.commands.Vision;
import org.usfirst.frc.team1025.robot.Robot;
import org.usfirst.frc.team1025.robot.subsystems.ChassisS ubsystem;
import org.usfirst.frc.team1025.robot.subsystems.VisionSu bsystem;
import edu.wpi.first.wpilibj.command.Command;
@SuppressWarnings("unused")
public class VisionAuton extends Command {
double centerX1;
double centerX2;
private boolean isCenter = false;
public VisionAuton() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.visionSubsystem);
requires(Robot.chassisSubsystem);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
synchronized (Robot.visionSubsystem.imgLock) {
Robot.visionSubsystem.centerX1 = this.centerX1;
Robot.visionSubsystem.centerX2 = this.centerX2;
// double TargetMidpoint = (centerX2 - centerX1) / 2;
// double disp = (TargetMidpoint - Robot.vision.IMG_WIDTH / 2);
@SuppressWarnings("static-access")
double Turn = centerX1 - (Robot.visionSubsystem.IMG_WIDTH / 2);
//+ centerX2 - (Robot.visionSubsystem.IMG_WIDTH / 2);
// double Turn = (centerX2 - centerX1) / 2 - Robot.vision.IMG_WIDTH / 2;
Robot.chassisSubsystem.getRobotDrive().arcadeDrive (-0.6, Turn * 0.005);
// Make this return true when this Command no longer needs to run execute()
public boolean isFinished() {
if(centerX1 == 237.0 + 10){
return isCenter = true;
else if(centerX1 == 237.0 - 10){
else{
return isCenter == false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
