Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 08-02-2017, 22:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: CIA 291 Robot Reveal
In the linked video, it was 9 seconds from motor activation to the touchpad activation. As you guys tune your climber and go into your matches, make sure you account for this! It is precious time taken off of your gear cycles. As a gear specialist ourselves, the whole act of climbing is something we found to be very important. You may be able to improve the time with just a knot at the right height.
It looks really good!
2017 Scoring Model
CAD Library | GitHub
Unread 08-02-2017, 22:53
Classified*'s Avatar
Classified* Classified* is offline
Just grab a hacksaw and go.
AKA: Julia Cecchetti
FRC #0291 (CIA: Creativity in Action)
Rookie Year: 2015
Classified* will become famous soon enough
Thanks!
And we have accounted for 10 seconds to hang at the end of the match. That was our first climb test, so we wanted to be gingerly with it. We will have the knot higher and just drive right into it in a match
Team291.com
Work smarter, not harder.
Unread 08-02-2017, 22:56
D_Price's Avatar
D_Price D_Price is online now
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
I agree completely with Jesse you may be better off with a monkey fist knot as soon as you spin onto the knot it should hook.
Team member 2004-2008
Team mentor 2008-20XX
http://www.team1708.com/
"Education is a powerful tool. Always use it to better someone else's life"
Unread 08-02-2017, 23:01
Rookie Year: 2015
We were using a monkey fist knot in the video, but have since changed it to a different, flatter knot that works just as well with our climber. I call it the triangle knot. It is flatter, because we had a problem with the rope wrapping around the ~1" monkey knot and stalling the winch because the effective diameter became too big. The new knot fixed this perfectly though.
Team291.com
Unread 08-02-2017, 23:19
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
What kind of rope have you settled on? Have you checked to make sure you can activate the touchpad before hitting the davit channel? From where I can see it could go either way.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 08-02-2017, 23:27
Rookie Year: 2015
As of now we are using a thinner solid braid rope. The vertical struts are meant to activate the touchpad, but we still have a lot of testing to do, and it's hard to be sure without an actual touchpad to try it on. If we do find that to be a problem, we are still a few inches under the 24" limit in the back, so we could add longer struts if we need to.
Team291.com
Unread 08-02-2017, 23:40
D_Price's Avatar
Engineer/Mentor
AKA: Derek
Apologies then I am colorblind I may have missed the knot. See you in week 3!
Unread 09-02-2017, 00:24
Rookie Year: 2015
Our practice robot is also coming along nicely! We plan on having the gear scorer on it, but not the winch as there is plenty of time for climb testing before bag day.
Team291.com
Unread 09-02-2017, 13:50
rocketgamer102 rocketgamer102 is offline
FRC #2544
rocketgamer102 is an unknown quantity at this point
Hello, I am with team 2544, your lovely neighbor from Harborcreek. I am wondering about the gear shoot. Is it a pilot pull up or a drop off?
Unread 09-02-2017, 14:08
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Drop off
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 09-02-2017, 14:47
Rookie Year: 2015
Hi 2544! We have the ability to do both, but we prefer to drop it onto the peg.
Good luck! And see you at Pittsburgh!
Team291.com
Unread 09-02-2017, 15:06
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
What is the gearing on your climber?
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 09-02-2017, 17:05
jodocsingh jodocsingh is offline
FRC #0948
jodocsingh is an unknown quantity at this point
Our team was having a difficult time determining how to attach our bumpers and I really liked your usage of wingnuts. How quickly would you estimate you are able to remove and replace your bumpers currently?
Unread 09-02-2017, 17:19
Rookie Year: 2015
This is our first year doing one piece bumpers, but so far they are great! We do not have all of the brackets attached for the bumpers yet, but right now one person can put the bumper on very quickly ( I haven't timed it, but I would guess under a minute). We have a bolt sticking up that is permanently mounted to the frame, and the holes on the brackets on the bumper line up with them, so a wrench is not required to tighten the wing nut. I can post a picture after practice tonight.
Team291.com
Unread 09-02-2017, 17:27
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We are using a monkey fist also, but at the top of the rope instead.
Looks great and see you folks in Pittsburgh.
