Go to Post 'We're back to square one! and while we're at it, let's redesign square one.' - Bethie42 [more]
Unread 04-02-2017, 23:53
charlier999's Avatar
charlier999 charlier999 is offline
FRC #1662 (Raptor Force Engineering)
charlier999 is an unknown quantity at this point
Help! Programing versa plantary encoder
Are team desided to put a encoder onto a versa plantary gearbox. The encoder uses the Talon SRX data cable to the talon's data port. From there, what do I program to get the data from the encoder and put it else where?
thx.
Unread 05-02-2017, 00:00
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Help! Programing versa plantary encoder
I highly recommend you read the TalonSRX software reference manual it should be able to answer most of your questions.
Unread 08-02-2017, 18:33
Thumbs down Re: Help! Programing versa plantary encoder
I looked at the Talon SRX Software Reference Manual and ... it went way over my head. all tho it explains a bit, it is still vary confusing.
I did fail to mention the use of the encoder
The use of encoder is to record the rotation of the end of a shaft to a gear that is attached to our shooter to record the angle of the shooter to set to different settings of angle for different distances.
Also. Does the transfer cable need to attach to the Talon it is using to supply power to the motor.
Thx.
Unread 08-02-2017, 21:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you're going to use the encoder function of the Talon SRX to control motor speed, it definitely makes sense to send the encoder input that derives from the output of the controlled motor back to that particular controller.
Unread 08-02-2017, 23:04
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
thx.
If the Talon data cable goes directly into the encoder board then it's a CTRE magnetic encoder. Talon software manual section 7.5.4
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 09-02-2017, 00:07
BDRessler's Avatar
BDRessler BDRessler is offline
Programming Lead
FRC #1828 (BoxerBots)
BDRessler has a spectacular aura aboutBDRessler has a spectacular aura about
Related question: do these encoders only work with talon srx? (we are using sparks)
Unread 09-02-2017, 07:36
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The SPARK does not have any encdoder inputs. You will have to send the encoder data to a couple of DIO ports on the roboRIO. See this thread for answers to the next few questions.
