Go to Post I have caught a very strong case of FIRST fever. - weinbergmath [more]
Unread 08-02-2017, 23:04
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
What wheel to use for the flywheel
Out team is trying to build a single flywheel shooter. Currently we are using a 4" colson performa wheel that is 2 inch wide. Despite Pid control and trying various compression, our shots are all over the place. Any suggestion on the wheel choice and the amount of compression that may improve our consistency will be greatly appreciated.
Thanks
Unread 08-02-2017, 23:08
Re: What wheel to use for the flywheel
Have you tried putting a second, identical wheel on the same axle? Or, how about splitting the 2" wheel into two 1" wheels? The resulting "groove" should allow a straighter track through the shooter. It's not an uncommon setup for FRC shooters.
Unread 08-02-2017, 23:14
Ken Lam
FRC #4719
Thanks for the suggestion. We will try that tomorrow.
Unread 08-02-2017, 23:25
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Colson's are too hard this year. Try a soft rubber wheel for your flywheel.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 08-02-2017, 23:51
Ken Lam
FRC #4719
We are starting to think along those line too. I think my team build a reasonably good cage and hood for the flywheel and we have done everything we knew to tweak it. We will look at a softer wheel.
Unread 08-02-2017, 23:55
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I really want to see slow motion footage of a ball leaving a shooter that has a soft rubber wheel. I'd guess that at the speed the shooter wheel spins at, there is enough centripetal force pulling outward on the wheel that it acts like a hard rubber wheel rather than a soft one.
Unread 09-02-2017, 00:03
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Try rolling the balls through the shooter by hand, putting them in the bottom and spinning the wheel with the robot powered off. This is a pretty subjective and variable thing, but you want the ball to resist going through somewhat without really getting stuck or sliding by freely. (There also should not be one spot early in the ball's path that is much tighter than elsewhere.) This is a rough indication of whether you have a dearth or excess of compression. If you have too little compression, some balls will probably not catch well and receive less energy than others. Conversely, if you have too much compression, the aggressive deformation the balls are undergoing can make their trajectories hard to predict upon exit.
The equalizing factor, as Clint said, may well be trying a softer wheel that allows more compression to come from the forgiving wheel rather than the balls.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 09-02-2017, 00:22
AKA: Clint Brawley
FRC #0364 (Fusion)
Originally Posted by s_forbes View Post
I really want to see slow motion footage of a ball leaving a shooter that has a soft rubber wheel. I'd guess (https://www.youtube.com/watch?v=Fps6S03aWyE) that at the speed the shooter wheel spins at, there is enough centripetal force pulling outward on the wheel that it acts like a hard rubber wheel rather than a soft one.
The flywheel has to grab the fuel consistently and bring it into the shooting mechanism, the colsons slip a lot before actually taking the fuel into the shooting mechanism, resulting in inconsistent velocity and distance.
YMMV, just some results from our tests.
Clint Brawley
USAF 1992-2013
Unread 09-02-2017, 00:39
Ken Lam
FRC #4719
Which wheel will you recommend?
Unread 09-02-2017, 01:28
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
The new andymark wheels.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 09-02-2017, 01:46
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Space and weight allowing, more massive flywheels can be more easily regulated using PID. Through conservation of momentum, a large mass flywheel will transfer less of its momentum to the fuel than a less massive flywheel for each shot. It will take longer to reach optimal shooting angular velocity, but will maintain that angular velocity much more easily. If it's possible you may look into that in addition to different wheel surfaces
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 09-02-2017, 01:51
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Just for clarity, I assume Anthony is referring to these, as well as the other compliant wheels AndyMark has released this past season.
To the OP, a picture of your current setup would help us all dig into the minutia of your design and offer advice, if you so choose.
Unread 09-02-2017, 02:04
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
https://www.chiefdelphi.com/forums/s...4&postcount=17
Not much has changed, really.
Unread 09-02-2017, 10:22
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Tom Line View Post
This is why I love the laws of physics. Everyone has to obey them all the time. They don't care who has been elected police commissioner, president, or dogcatcher.
Richard Wallace
since 2003
Unread 09-02-2017, 11:10
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Our initial prototype used the 4" traction wheels that have come in the KoP in the past (very hard). It worked well enough, but even with only a moderate amount of compression you could hear/see the CIM motor powering it practically stall when a ball went through. Switch that out to the AndyMark compliant wheels, and now with the same setup (same compression, same motor, same gear ratio, literally the only difference is changing one 4" wheel for another) we can feed in a whole row of balls without any noticeable slowdown with the motor. The compliant wheels really do make a difference.
2016: Lake Superior WFFA
