Go to Post 71% efficiency is best efficiency. ;) - Chris is me [more]
Unread 08-02-2017, 20:40
charlier999's Avatar
charlier999 charlier999 is offline
FRC #1662 (Raptor Force Engineering)
charlier999 is an unknown quantity at this point
Post Pneumatics code problems.
Recently, I have been dealing with newly written pneumatics code not actuating Cylinders for a gear holder and shifters.
This is what I am trying to do
PHP Code:
"A" button is pressed Cylinder extends > "A" button is pressed again Cylinder retracts
I have tried to use a bool to act as a to swich between True and False when the cylinder extends or retracts, but that didn't do what I wanted above. Is there any other way of doing this.
Please ignore spelling mistakes in comments in code
If there is any other mistakes in the code that are not related to Pneumatics, feel free to say so.
Robot Code \/
#include <iostream>
#include <memory>
#include <string>
#include <IterativeRobot.h>
#include <LiveWindow/LiveWindow.h>
#include <SmartDashboard/SendableChooser.h>
#include <SmartDashboard/SmartDashboard.h>
#include "WPILib.h"
#include "CANTalon.h"
class Robot: public frc::IterativeRobot {
public:
//    Other Decerations                                  //
	bool shifter_varable = true;
	bool gear_enabled = false;
//   Deceration of Objects                               //
	Joystick *driver;
	Joystick *driverV2;
	Joystick *op;
	CANTalon *drive_right_a, *drive_right_b, *drive_left_a, *drive_left_b;
	CANTalon *intake;
	CANTalon *aggitater;
	CANTalon *shooter;
	CANTalon *climber;
	RobotDrive *drive_base;
	Compressor *compressor;
	DoubleSolenoid *gear;
	DoubleSolenoid *shifter;
	//WIP  \/
	//Encoder *shooter_encoder;
	Robot() {
//    Asigning Objects to Componints and Electronics     //
		driver = new Joystick(0);
		op = new Joystick(1);
		driverV2 = new Joystick(2);
		drive_right_a = new CANTalon(8);
		drive_right_b = new CANTalon(9);
		drive_left_a = new CANTalon(1);
		drive_left_b = new CANTalon(2);
		intake = new CANTalon(4);
		shooter = new CANTalon(7);
		climber = new CANTalon(6);
		aggitater = new CANTalon(3);
		drive_base = new RobotDrive(drive_right_a, drive_right_b, drive_left_a, drive_left_b);
		compressor = new Compressor(0);
		gear = new DoubleSolenoid(1, 3);
		shifter = new DoubleSolenoid(2, 4);
	void RobotInit() {
//                Robot vision Code                      //
		auto cam = frc::CameraServer::GetInstance();
		cam->StartAutomaticCapture();
//                Robot Compressor                       //
		compressor->SetClosedLoopControl(true);
	void AutonomousInit() override {}
	void AutonomousPeriodic() {
		drive_right_a->Set(1.0);
	void TeleopInit() {}
	void TeleopPeriodic() {
		// drive train; (left joystick; y axis; left drive) (right joystick: y axis; right drive)
		drive_base->TankDrive(-driver->GetRawAxis(1), -driver->GetRawAxis(5));
//                 Drive Remote                          //
		//shooter; left bumper
		if(driver->GetRawButton(5)) {
			shooter->Set(0.60);
		}else{
			shooter->Set(0.0);
		//intake in; right trigger
		if (driver->GetRawButton(7)) {
			intake->Set(-1.0);
		}else{
			intake->Set(0.0);
		//aggitator; "B" button
		if (driver->GetRawButton(3)){
			aggitater->Set(1.0);
		}else{
			aggitater->Set(0.0);
		//shifters; "A" button
		if (driver->GetRawButton(2)){
			if (shifter_varable==true){
				shifter->Set(DoubleSolenoid::Value::kReverse);
				shifter_varable = false;
			}else{
				shifter->Set(DoubleSolenoid::Value::kForward);
		//Gear open close; "Y" button
		if (driver->GetRawButton(4)){
			if (gear_enabled == true){
				gear->Set(DoubleSolenoid::Value::kReverse);
			}else{
				gear->Set(DoubleSolenoid::Value::kForward);
				gear_enabled = true;
//  		       Operator Remote                       //
		//climber up; right bumper; op
		if (op->GetRawAxis(1)){
			climber->Set(1.0);
private:
START_ROBOT_CLASS(Robot);
Sorry for being a long post
Thx.
Unread 08-02-2017, 20:44
Re: Pneumatics code problems.
Pneumatics are run through a manifold.
If this ends up being some thing non related to programming, I will reply if it is.
Thx.
Unread 08-02-2017, 23:06
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
bool wasAPressed = false;
// then in in teleopPeriodic...
if (driver->GetRawButton(2)) {
    if (!wasAPressed) {
        wasAPressed = true;
        shifter->Set(shifter->Get() == DoubleSolenoid::Value::kReverse ? DoubleSolenoid::Value::kForward : DoubleSolenoid::Value::kReverse);
} else {
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 09-02-2017, 17:25
Does the word "Value" in
represents the value in the Double Solenoid is pluged into the PCM or something else?
Thx.
Unread 09-02-2017, 17:53
Never mind what I said. I found out what it means
Thx.
Thx.
Unread 09-02-2017, 22:01
Originally Posted by euhlmann View Post
    if (!wasAPressed) {
        wasAPressed = true;
} else {
The one problem with this code is that when i press the button longer than 1/50th of a second(50 cycles per second the rio reads the code), it hastily switches back and forth between on and off. Is there any way of fixing the problem or do i just need to have extremely fast fingers for that button.
Thx.
Unread Yesterday, 01:18
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Thx.
My code shouldn't do that. Notice how it sets a flag wasAPressed to make sure it doesn't continuously run shifting. Make sure wasAPressed is a member variable, not a local variable
Unread Yesterday, 18:23
//later in teleopPeriodic
  if (!shifter_varable){
}else{
all tho i did the exact same thing except change the name of the wasAPressed to shifter_varable. It still does the exact same thing as before, going hyper-speed switching back and forth.
Unread Today, 01:10
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Ok let me make it a bit more clear:
// File: Robot.cpp
class Robot: public IterativeRobot {
public:
    bool wasAPressed = false; // MEMBER VARIABLE. not local variable
    // robotInit, teleopInit, autonomousInit, autonomousPeriodic, etc
    void teleopPeriodic() {
            if (!wasAPressed) {
                wasAPressed = true;
        } else {
Please read: http://www.cplusplus.com/doc/tutorial/classes/
