Go to Post 4 is kind of like 5 - Jaine Perotti [more]
Unread 09-02-2017, 00:03
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: What wheel to use for the flywheel
Originally Posted by lamk View Post
We are starting to think along those line too. I think my team build a reasonably good cage and hood for the flywheel and we have done everything we knew to tweak it. We will look at a softer wheel.
Try rolling the balls through the shooter by hand, putting them in the bottom and spinning the wheel with the robot powered off. This is a pretty subjective and variable thing, but you want the ball to resist going through somewhat without really getting stuck or sliding by freely. (There also should not be one spot early in the ball's path that is much tighter than elsewhere.) This is a rough indication of whether you have a dearth or excess of compression. If you have too little compression, some balls will probably not catch well and receive less energy than others. Conversely, if you have too much compression, the aggressive deformation the balls are undergoing can make their trajectories hard to predict upon exit.
The equalizing factor, as Clint said, may well be trying a softer wheel that allows more compression to come from the forgiving wheel rather than the balls.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
