Go to Post OMG this topic again. Those who stir the pot should lick the spoon. - nuggetsyl [more]
Unread 08-02-2017, 12:16
bowmanb bowmanb is offline
AKA: Bruce Bowman
FRC #3991 (KnightVision)
bowmanb is an unknown quantity at this point
Re: H-Drive Strafing issues
We also used a pneumatic cylinder as a "spring" on our H-drive setup in 2015. We put the cylinder on its own air circuit and tuned the pressure to the point where we got the max down-force without lifting the "normal" wheels too much. ("too much" being a technical term meaning the point where things don't work correctly )
Unread 08-02-2017, 13:16
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Originally Posted by GeeTwo View Post
Correct. It didn't matter whether we ran on bare floor or carpeting; we never got a useful strafe with fixed mounting, even when we tried a slot and use cable tension to hold the gearbox/wheel down.
What chassis did you use?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 08-02-2017, 13:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We've modified and built atop the AM14U2 for three years (2015-2017). Does it matter?
Unread 08-02-2017, 13:24
Citabria42's Avatar
Citabria42 Citabria42 is offline
AKA: HamGod
FRC #0706 (Cyberhawks)
Team Role: Electrical
Citabria42 is an unknown quantity at this point
What we did in 2015 is have 2 pneumatic pistons on either side of axle, to push down when needed with a single trigger pull.
Unread 08-02-2017, 13:27
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
I think it might.... we are using Vex, so it may be more reliable (since it is a kit)
Unread 08-02-2017, 18:16
Mulcahy's Avatar
Mulcahy Mulcahy is offline
FRC #0987 (High Rollers)
Mulcahy is on a distinguished road
We used a copy of 148's design in 2015. https://www.youtube.com/watch?v=uL-NnuZzOkU It is the easiest way to accomplish H drive... - no springs, no pneumatics, no extra controls, and it accommodates changes in floor height seamlessly. I wish I had invented it.
Unread 08-02-2017, 22:40
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Your link is to a match not a design. What does that design mean, and how does it make H drive easier to accomplish?
I don't get your gist. OBTW, the AM14U2/3 is also a kit. Possibly not germane, but our off-season pneumatic strafe had a number of variables really screwed up because we were using what we had vice what was best for the application, but it worked first try. Barring further findings, I cannot and will not recommend anything other than some definite control over the applied force of the strafe wheel to the carpet, whether spring or pneumatics or synthetic muscle or cosmic pressure.
Unread 08-02-2017, 22:47
pmattin5459's Avatar
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
It doesn't matter. First off, both are kitbots, and both are somewhat reliable chassis. I like Vex better personally, more options for entirely COTs chassis. Anyways, you simply aren't going to get the right amount of compression between the strafing wheel and the ground without actuating it. The best way to do so without mucking about in custom manufacturing is to grab a versadrop module and slap it into the place currently occupied by your strafing wheel. Position it right, and you should be able to drop the strafing wheel by actuating a single piston.
At this point, though, if you want to delay it further, then continue to deliberate. But you've only got a couple weeks left, and if you want this thing driving well by the end of build, you're going to need to either order the parts you need very quickly and get it done, or just switch to a basic 2+2 or 6-wheel tank drive.
Unread 08-02-2017, 22:48
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Your link is to a match not a design. What does that design mean?
Wait are we talking about the same thing here???? I'm talking about this-
https://content.vexrobotics.com/vexp...-top-trans.png
And andymark has a H drive kit??
Unread 09-02-2017, 04:41
AKA: Patrick Mattin
Rookie Year: 2015
Oh I thought you guys were using VersaChassis. Vex still sells that old stuff?
Anyways, you'll probably want to use that Robowranglers method of actuating the strafing wheels. Or switch to a tank drive. Given that you have your wheels in the corners, a 2+2 (2 traction in front, 2 omni in back) would probably work alright.
Unread 09-02-2017, 08:37
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
It is possible to make a ridged mounted H-Drive work, but not work well.
In 2015 we gave H-Drive a try without realizing the need for the center wheel to be articulated, by the time we were done we had offset the center wheel 1/16"-1/8" below all the other wheels on the robot, this resulted in some very odd rocking in the chassis and the strafe only worked about 75% of the time (because the carpet floors are never perfectly flat). It wasn't accurate enough to use during autonomous, but driving it manually it worked ok.
If I had to build an H-Drive again though I would definitely put it on a suspension.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 09-02-2017, 09:27
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Apparently not; you asked about the chassis, not the strafe mounting.
Getting the strafe wheel at the same height as the other four is NOT what you need. Even when we had about 1/16" of a drop on ours relative to the corners, it did not provide enough traction to move the robot well. By the time we got the drop deep enough to produce consistent strafing, we had problems driving in forward and reverse. There just is no right height for a rigid mount.
Unread 09-02-2017, 09:37
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I had moderate success with a fixed mount h drive in the fall of 2014 albeit the entire chassis was made of folded 1/8" polycarbonate. The flex in the PC acted like a suspension for all the wheels.
All in all I would definitely take a look at 148's robots both their 2010 and 2014 strafe wheel assemblies.
ID:	21760  Click image for larger version
461 Westside Boiler Invasion
45 Technokats
Unread 09-02-2017, 10:07
cbale2000's Avatar
AKA: Chris Bale
Originally Posted by Peyton Yeung View Post
...albeit the entire chassis was made of folded 1/8" polycarbonate...
I hate to go off topic, but in all seriousness how did this drive not self-destruct immediately? We've used solid 3/8" polycarbonate plates for our drive system for several years and it barely holds up (it tends to crack a lot). We keep using it because of the weight savings but we have to be very careful with it.
Unread 09-02-2017, 10:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
polycarb = tough ≠rigid
I suspect you were using acrylic (plexiglass), not polycarbonate (lexan). See my post in the Quotes thread yesterday for a description of the difference.
Last edited by GeeTwo : 09-02-2017 at 10:17. Reason: Moved equation up, added link.
